Autometer Speedo Doesnt operate?
Old 02-02-2013, 11:44 AM
badazz81z28's Avatar
Default Autometer Speedo Doesnt operate?
Drove the LS powered 78 Camaro today, everything seems good except, the Speedometer doesn't work. Before I had the LS, the Speedo was connected directly to the VSS and worked fine.
Now I have the LS, the VSS is incorporated into the harness and the speedometer is connected to the VSS signal wire from the PCM.
What could be the problem?
Old 02-02-2013, 11:48 AM
rotor vs. piston's Avatar
I likely didn't do it the best way myself, but I finally ended up just tapping (splice) into the VSS directly.
Old 02-02-2013, 12:32 PM
Worked fine before...If I did that, it would surely operate.
I wonder what the real issue is though.
Old 02-02-2013, 01:24 PM
130fe's Avatar
Did you check your all of the connections on the speedo? Maybe something got disconnected on accident.
Old 02-02-2013, 02:26 PM
ls1nova71's Avatar
Have you tried re-calibrating it? When you calibrate it if it has a digital odometer, which it should I think, it will count off pulses. When you get close to 4000 stop. If your tune is correct it will be correct. Tapping directly off the VSS will sometimes screw with the PCM and can make the transmission do funny things.
Old 02-02-2013, 05:26 PM
IIRC the real answer is, it's because the ECM sends sign wave and the Autometer wants square wave signals.
Old 02-02-2013, 06:09 PM
patooyee's Avatar
This is what I found on my E40 ECM. The ECM converts the signal before outputting it. I had to connect directly to VSS.
Old 02-02-2013, 08:00 PM
Well, I guess I will tap into it...
Anyone know about the TACH fix? Mine was set to V8 and was reading too low, so I found on the web that it should be in 4 cylinder mode, well now it reads about 1000rpms high...
V6? Or is something not right?
Old 02-02-2013, 08:04 PM
patooyee's Avatar
There is some sort of trick where you have to wire in a diode or resistor or something. My memory is hazy on it but it has been covered here multiple times I think. Search for it and when you find it post a link here please. But yes, it needs to be in 4-cyl mode.
Old 02-02-2013, 08:09 PM
patooyee's Avatar
Originally Posted by rotor vs. Piston
iirc the real answer is, it's because the ecm sends sine wave and the autometer wants square wave signals.
Old 02-02-2013, 09:23 PM
S10xGN's Avatar
Yup, the ECM output will not drive the Autometer speedo, you need the raw signal straight form the sensor.
Old 02-02-2013, 09:29 PM
Sounds good...Easy fix there...
Now I will have to deal with the Noisy fuel injectors!!
Old 02-02-2013, 09:37 PM
ls1nova71's Avatar
Why does mine work perfect then? I originally tapped into the VSS, but it would screw up the shifting of the transmission. I hooked a scanner up to it and the MPH would jump around once you got to around 65 MPH or so. It would read 65 then go to something like 42 and then 58. Made the trans do wierd things, so I hooked it up to the speed output from the PCM, set the ppm to 4000 and it works flawlessly. It's a 2 year old Autometer speedo, my original one was replaced by Autometer for a factory defect.
Old 02-02-2013, 09:40 PM
What Auto-meter do you have? I have the Ultra Lite, and its completely dead running from the PCM. Worked flawlessly when was a stand alone unit with the SBC.
Old 02-02-2013, 09:51 PM
From my research, my gauge should read the sine wave (2 wire VSS). Do you mean the PCM sends out a square wave?
Old 02-02-2013, 09:53 PM
ls1nova71's Avatar
This one. http://www.autometer.com/cat_gaugede...id=3012&sid=19 But I can't imagine they would have different guts? Didi you try to re-calibrate it?
Old 02-02-2013, 10:30 PM
In the directions it says to tap into the VSS sender itself.
The gauge is picking up zero signal. I have calibrated this speedometer many times before, No matter how much it's off, it at least will move and despite being inaccurate. Something isn't right.
http://static.summitracing.com/globa...structions.pdf
Old 02-02-2013, 10:55 PM
ls1nova71's Avatar
And when you call them to tell them its messing up your trans shifting they will tell you to try several different resistors. I did that and it worked better, but still wasn't right.
When you calibrate it, does the odometer count off pulses? Mine wouldn't move when I switched it either, but after driving it and calibrating it to 4000 pulses it worked.
Old 02-03-2013, 09:26 AM
I'll check. The needle doesn't move at all, I will see if it counts pulses today.
Quick Reply: Autometer Speedo Doesnt operate?
