Lost small oil pick up tube bolt, can I use generic hardware store bolt?
Old 02-05-2013, 09:00 AM
turbotuner20v's Avatar
Default Lost small oil pick up tube bolt, can I use generic hardware store bolt?
I must have set the oil pump/pick up tube bolt aside during removal from my original engine and lost track of it, because I can't find it now. It's $6 and takes 4 business days to get through my local dealer, is it ok to just get a matching bolt from the hardware store and use some blue loctite? Torque spec is like 9 lb-ft, so it seems like it wouldn't matter as long as the length, head and pitch are the same.
Old 02-05-2013, 09:13 AM
Gunslinger09's Avatar
Yep you will be fine with a bolt from the bin at Napa.
Old 02-05-2013, 09:25 AM
Tainted's Avatar
sure, and you should grab one of those pickup tube girdles where you can have two bolts in it isntead of one.
Old 02-05-2013, 09:42 AM
I'm looking to get things buttoned up pretty soon, not sure I want to order and wait on any parts... is there some flaw with the original design w/ 1 bolt that is fixed with the girdle? Or did they just make it since there's 2 bolt holes and they figured they may as well use both?
This one I assume?
http://www.brphotrods.com/mm5/mercha...gory_Code=CNV6
Old 02-05-2013, 09:48 AM
Tainted's Avatar
yup thats it. its not a MUST but it can help from pinching that damned oring and maybe give it a bit tighter seal. i plan on picking one up.
Old 02-05-2013, 09:50 AM
I've got the motor on a stand, so I should be able to get the o-ring situated ok. With a spec of 9 ft.lb I can't imagine it needs too much pressure to seal the o-ring. I'll probably skip it.
Old 02-05-2013, 04:43 PM
RezinTexas's Avatar
you'll be fine with the one-bolt setup, especially with the engine on the stand. apply plenty of lube and work it in slow.
Old 02-05-2013, 05:42 PM
Tainted's Avatar
Giggity
Old 02-05-2013, 09:04 PM
Wait.... What?
Old 02-06-2013, 06:16 AM
Busted Knuckles's Avatar
Might try a bottle of wine first, maybe a gift of some bling...
Quick Reply: Lost small oil pick up tube bolt, can I use generic hardware store bolt?
