Special kind of Twin turbo
Has anyone ever thought of using a smaller (60 series turbo) on the passenger bank of a 6.0L twin turbo motor and a larger say (76 series turbo) on the driver side???
I'm thinking that the 60 series would spool instantly and give tons of torque down low and once the air velocity got to the point where the big turbo kicked in you would have the best of both worlds.
I would think that with a FAST XFI system you could adjust fuel with the small turbo and then when the bigger kicked you could ramp up the fuel map.
What does everyone think?? Am I missing something??
I would think the back pressure would be unreal on the small turbo once the big turbo took over.
now if the turbos where joined sum how from bank to bank as the back pressure started building in the small turbo it would feed over to the big turbo keeping equal pressure on each bank
Very intrestin topic....Ive been looking into a compound set up for quite some time now. Its a little mind boggling, but looks doable. Ive wanted to run a 67mm turbo feeding a 88 or bigger on a 408. I see no real benifit from a set up like this over properly set up turbo combo but it does have the wow factor and sounds wild!
Im going to do it before the end of the year....
I'm just trying to find a way to make a lot of torque down low in the rpm range (say 1500-1800 rpm). I hate big 3500 rpm stall convertors.
A lot of people say its one or the other but I don't think it needs to be.
Check out this website I found that talks about parallel, sequential turbo setups. Great article!
http://www.autozine.org/technical_sc...duction_3.html
