Car turns over then dies after starts
Old 02-10-2013, 12:38 PM
Coza427's Avatar
Default Car turns over then dies after starts
Today I started my 99 trans am and it idled fine then suddenly died..I tried starting it again and it turns over and immediately dies..I hear my fuel pump turning on and working but it seems like it just cuts off the fuel pressure when it starts. I start the car it does a rev to 1900 and just dies and then I hear the fuel pump sending more fuel up..so I try to start it again and it just revs up and dies. I have recently done a cam swap on it and it ran perfect, it just randomly shut off this morning. Any help would be great!
Old 02-10-2013, 12:45 PM
luigiandme's Avatar
Seems like it's cutting fuel for some reason after it starts.
Check your MAF, pull it off and clean it with CRC Mass Air Flow Cleaner.
Check to see if your security light is flashing.
What are some recent thing you've done to the car? a little background information may go a long ways.
Old 02-10-2013, 12:52 PM
Coza427's Avatar
I have checked my maf and it is very clean. My security light is not flashing or anything..the only things I have done to the car is a cam, fast 92 intake, 92mm tb. Svo 42 lb green top injector, slp lid, 1 3/4 in pacesetter longtubes with a 3in off road x-pipe. It's just weird because it ran fine for 3 weeks with absolutely no problems...and it decides to act up today..could it have anything to do with my fuel filter?
Old 02-10-2013, 12:54 PM
luigiandme's Avatar
Put a fuel pressure gauge on that ******.
Although a pressure gauge wont tell you flow, its a good starting point.
It maybe a fuel filter..
No vacuum leaks or anything? or it doesnt run long enough to run out & listen?
Old 02-10-2013, 01:15 PM
Coza427's Avatar
Yeah there are no vacuum leaks..I'm going to go get the pressure and see what's going on there..could it have anything to do with my PCM/tune..
Old 02-10-2013, 02:11 PM
Coza427's Avatar
Alright I just ran a fuel pressure test and it holds holds above 50 psi all the time..what else could it be!!
Old 02-10-2013, 04:53 PM
SMOKINV8's Avatar
You really need a scanner of some sort to see what it's doing. Outside of that, with as an extreme condition as it is (as in not running), a visual inspection under the hood should give you some insight. Kinda sounds like a big vacuum leak.
Old 02-10-2013, 04:55 PM
sreve's Avatar
Does the service eng light go out when it starts? or does it have codes in it?
Old 02-10-2013, 07:03 PM
Coza427's Avatar
Ok guys some how It started >_<. I unplugged the battery and let it sit for 3 hours, and cleaned the maf really really good..and it sputtered back up and then it ran ok some how..I'm really guessing it was my maf it just looked really really clean..doesn't make it clean.. But thanks for the help
Old 02-11-2013, 12:32 PM
LS1Tech Sponsor
Slowhawk's Avatar
The battery reset something.
Quick Reply: Car turns over then dies after starts
