Wastegate size help on turbo swap, boost creep?
Old 02-12-2013, 11:51 PM
Jetn3's Avatar
Default Wastegate size help on turbo swap, boost creep?
I currently have a 5.3/eBay gt45 combo with a tial 38mm wastegate and holds 8-9 psi just fine on a 8-9 psi spring. I also have a 3" dp and soon to be 3.5" straight pipe out back. I'll be upgrading to a pt7675cea and I want to run the same 8-9 psi for now. Will the 38mm tial be big enough?
The gt45 has a pretty big turbine already (77ex/87.4in/1.05a/r) and the pt's turbine is a tad smaller. So do I need to worry about boost creep by swapping to a turbo with a slightly smaller turbine, when bigger turbine turbo works fine? Does the compressor side come into play with boost creep?
Old 02-13-2013, 06:24 AM
LS1NOVA's Avatar
It will be on the edge or working. Only time will tell. The PT is much more efficient.
Old 02-13-2013, 07:27 AM
c0ncEpT's Avatar
It really depends on gate placement IMO.
Old 02-13-2013, 08:09 AM
Moderator
denmah's Avatar
let it rip, if its no good throw on a bigger one or a 2nd one
Old 02-13-2013, 10:25 AM
Twin turbo c5's Avatar
I run a pt76 on a lt1 with a 38 tial wg for years in my Fairmont. It worked great but placement is key. Mine was close to turbo
Old 02-13-2013, 10:40 AM
Jetn3's Avatar
Ok cool, I'll try the 38 and go from there. Thanks guys!
Old 02-13-2013, 10:43 AM
Jetn3's Avatar
How much boost do you run on the 38 TIAL?
Old 02-13-2013, 10:45 AM
I run 16 psi back then. we pushed it to 20 psi on the dyno one time and it made 740 at the wheels.
Old 02-13-2013, 12:06 PM
H&P Performance's Avatar
I would have to agree...The 38mm Tial should be fine for now. If you had an ebay wastegate I would definitely upgrade to a 44mm tial at least. We had a 38mm ebay wastegate with a 70mm turbo as one of our initial setups on a 2000 Trans Am and boost creep did it in. Definitely put some money into wastegates.
Quick Reply: Wastegate size help on turbo swap, boost creep?
