Long Tube Headers
Long Tube Headers
So I finally ditched the mid tubes for the long tubes, but when I got the car tuned it had the mids. So my question is will the PCM compensate for that extra little airflow? I know he tuned it with a 13.00 afr so that's what had me wondering if the extra air flow will lean it out or??
Thanks Ed..
Most tuners will give you a wicked deal for a small adjustment like you need. I would be contacting your tuner and see what they would be willing to do. All you need is a little adjustment to your fueling tables and maybe an adjustment to your timing tables. Even just a quick WOT run with a WB, just to touch it up
9-Second Club
There is no reason to change the spark advance for longer header tubes. LOL
I have dyno tested several like this, some may lean slightly, many are fine. Odds it's OK are better than 50-50. The MAF "sees" the added air flow, and if everything is OK more often than not it's still OK.
You really don't think idle timing would need a little clean up going to long tubes? I would think that his timing is going to drop a little at idle to keep exhaust temps high enough to keep his O2's reacting properly, especially if the engine is cammed?
Ever since I installed the long tubes the car drove a little rough but when I get down on it it's smooth as butter. I thought the PCM had to learn its new environment but it didn't. So I unplugged the o2 sensors and the car drove PERFECT! Why is that? O2 sensors are new. Could it be that their not getting hot enough?
