4l65e
Moderator
An incorrectly installed converter is the likely problem, and it true, it likely also broke the pump rotor.
This thread might help you:
https://ls1tech.com/forums/automatic...0e-my-ls1.html
See my post #8.
Do you remember if there was a gap between the converter and the flexplate?
When there is, you can turn the converter very easily before the first bolt is installed.
See my post #8.
