Valve Springs
Old 03-05-2013, 04:19 PM
tylerj's Avatar
Default Valve Springs
I am gonna be running a lq4 with 317 heads. I have a gt4788 and plan to run about 20lbs of boost but not sure which valve springs to run. Any suggestions? thanks.
Old 03-05-2013, 05:13 PM
SSZ
SSZ's Avatar
I have a set of Brian Tooley racing springs. Very nice pieces especially for the money. I have also seen others use the PSI' with good luck. I think Nate here uses a type of Lunati that he has good luck with. Do a search. Then ask further questions. Not PSI' but PAC's. Sorry about that.
Old 03-05-2013, 05:54 PM
steveo_f8's Avatar
Brian Tooley here as well... Im sure most are going to want to know more about your set up for their opinon though.
Old 03-05-2013, 06:20 PM
Brian Tooley Racing's Avatar
Depending on cam ramp speed and valve weight, the Platinum springs work great. With something like the Comp HUC or Extreme RPM lobes and stock valves my springs are good to 26+ lbs of boost.
Here's a video of the Platinum springs in action, turning 7300 rpm through the traps with 20 lbs of boost with Comp HUC lobes, right after he won the Holley LS Fest True Street class. Enjoy!
Old 03-05-2013, 06:39 PM
SSZ
SSZ's Avatar
That stang is pulling hard. Nice vid Brian. I think i have the platinums. Great pieces. Very nice quality.
Old 03-05-2013, 06:48 PM
anheuserbusch08's Avatar
i been ordering bt racing springs for my last 3 builds and they are still holding up great! fast shipping and a great product and i run lsl lobe cams (.624 lift) too! i just got a new set in a couple of days ago im Kenneth Mr B! thanks for your product and service!
Old 03-06-2013, 10:01 PM
LS1NOVA's Avatar
Brian Tooley!!!
Old 03-07-2013, 07:32 PM
SSZ
SSZ's Avatar
Originally Posted by LS1NOVA
Brian Tooley!!!
Sorry Nate. Thought you used Lunati. My bad!
Old 03-07-2013, 09:12 PM
LS1NOVA's Avatar
Ive used the Lunati but Tooley has quality parts at reasonable prices and if you have a question or an issue you pick up the phone and he answers.
Old 03-07-2013, 09:29 PM
ronnieforrester's Avatar
Just got mine from Brian this week-almost went with the PAC 1218's but for $70 more why take the chance and buy the best spring the first time.
I read it somewhere, may have been here, Buy once cry once, I hate rebuying parts and selling the old ones at a loss but Ive done it plenty.
Quick Reply: Valve Springs
