I think that I smoked my clutch tonight?
Did a H/C/I last month. Took it the drags tonight. A nice 2nd gear burnout in the water box with the line lock. Cut a -.049 light (red light) pulled a 1.667 60ft. Had a hell of a time trying to hit 2nd, could not hit third. Only went 8.332 @84.75 MPH. Now getting in to gear is very hard, cant get rev, had to push it. Peddle engages right off the floor. The clutch is a LS6 with 30K. Do you think a bleed is in order? or is it smoked?
I have flushed the master, by taking the line off the trans (as per Tick). But I am not sure about the bleeder on the slave, is it a hex head bolt above where the line goes into the trans?
I have been reading them all day! The hex I found is not it. I just now found it after looking a photo of a slave.
Okay, been reading all weekend. I had the black clutch fluid of death syndrome. Long story short. I replaced all of the clutch fluid (no drill mod) and it seems to okay. So is this a temp fix? Or is my clutch on its last legs?
