Th400 vs Glide with turbo?
Old 03-17-2013, 08:44 AM
T/ALT1's Avatar
Default Th400 vs Glide with turbo?
Well I got my turbo, put the rear under the car, swapping gears from 3.73's to 3.50's, now it's time to decide wether to build a Th400 or a glide. The car should weigh no more then 3100lbs and I already have a good 4k Precision Industries converter. I was going Th400 but it will be harder to leave with and I'd like something that will consistently leave well at the track. Give some results from swapping.
Old 03-17-2013, 08:56 AM
Wicked69's Avatar
I love the glide for a turbo package. My car is heavy, heavy and I just recently switch from 3.90's and a TH400 to 3.42's and a glide. Car just ran a best of 6.07@113mph. I also switched from a 5.3 to a 6.0 though so hard to tell true improvement but with just the trans and gear swap I at least went from 6.31's to 6.26 with less boost.
With the weight of your car I would go glide. I also like the idea of one shift.
Old 03-17-2013, 08:58 AM
T/ALT1's Avatar
Yeah your car is one that makes me want to glide, it's running hard for as heavy as it is. Did you ever put an inter cooler?
Old 03-17-2013, 09:02 AM
Wicked69's Avatar
Not yet. I plan to but am not worried about it while the weather is so cool. My IAT's are still around 215 but again that is measured before the E85 hits it. I have my KR to low 1's and no burst knock so I am not worried about it. My timing is only at 17 now. Dudeman helped me with my timing table.
Old 03-17-2013, 09:16 AM
zapp109's Avatar
1/4 mile car or 1/8th?
Old 03-17-2013, 09:32 AM
T/ALT1's Avatar
Mostly 1/4mile and a little street duty.
Old 03-17-2013, 09:45 AM
zapp109's Avatar
whats your power level gonna be? Reason i ask id i had a TH400 with my old ls6 nitrous setup. With a 28" tire 3.55 gears i was about out of gear around 135-140mph
Old 03-17-2013, 10:04 AM
T/ALT1's Avatar
Well they both have the same high gear ratio so that doesn't really make a difference. I don't know what the power level will be but hoping for 750rwhp. I may have to either go with 3.27 gear or. 30" tires once I get the car dynoed and make a few passes at the track I'll go from there. I'm thinking the glide would be a good combo but I want to able to do 1.3 60's once it's dialed in.
Old 03-17-2013, 10:09 AM
zapp109's Avatar
yea id do the 3.27s then. Ive never driven a glide so i cant help you but on all our bracket cars we run th400s. My turbo lsx im going built 4l80e so i cant help you too much just wanted to give you some input on the gear choice.
Old 03-17-2013, 10:15 AM
boosted95's Avatar
I have a glide behind my ls twin set up in my mustang. It's nice. Stock case glide can hold good power, not as heavy as a 400. I've heard guys taking 1st gear out of the 400 because they have so much torque in first you don't need it in that light of a car. and also losses some weight.
Old 03-17-2013, 10:31 AM
T/ALT1's Avatar
Thanks, boosted 95, how much power do you make, ets and gear ratio are you running?
Old 03-17-2013, 01:24 PM
topend's Avatar
both my turbo cars run th400 ,both cars are heavy. If it were a tube chassis car i would run a powerglide .A power glide in a heavy car makes it a dog.
Old 03-17-2013, 02:25 PM
T/ALT1's Avatar
I had originally planned to go th400 but I've noticed a few cars running quick with glides and turbo'd setups. My local track doesn't have the greatest prep so that's another reason I like the glide b/c it won't hit the tire so hard with the higher first gear ratio.
Topend how quick do your turbo cars run?
Old 03-19-2013, 03:52 PM
boosted95's Avatar
I'm running a 180 straight cut gear with a 3:55 gear in the rear. Haven't taken it to the track yet so i can't give you no et's. But on the street I feel like I'm in a stock car. lol My car is around 2900 with me in it.
Old 03-19-2013, 09:28 PM
T/ALT1's Avatar
Well I'm going to go with the glide, since my car is light 3100lbs with me in it. I should be Able to leave with 10+psii and get the car moving out quick with less traction problems. If it doesn't leave hard enough I'll spray n20 for 1-2 seconds and that will make it scoot!
Old 03-19-2013, 09:36 PM
Blackpanther99's Avatar
Ill go with the glide setup as well since you want that good launch. A TH400 wouldnt be a bad idea either IMO, but a glide will suit you better for what you want.
Old 03-19-2013, 11:55 PM
GueSS Who's Avatar
385CILSX with LF88
TH400 here with 3.70 gears
1.172 60ft on 275s. More gear is always better IMO (as long as you can hook it up)
car weighed 3480
Old 03-20-2013, 02:05 AM
stangtrader's Avatar
Im having the same delema right now as well.my cars mostly a street car tho but I think with the right stall with my small turbine the car shouldn't be a dog around town
Old 03-20-2013, 02:19 AM
T/ALT1's Avatar
I agree with th400 making better ET's as long as you can get it hooked up. The local track I race at seldolmly hooks good only a few events per year. I would be a lot better off being able to get down the track easily then struggle with traction issues. Lastly the three quickest turbo 5.3's that all run 8's in the 1/4 all run glides.
Old 03-20-2013, 02:22 AM
9Green-Z8's Avatar
has any one ran both on a turbo set up?
Quick Reply: Th400 vs Glide with turbo?
