concerned motor swap.
Old 03-20-2013, 11:06 PM
ws6guy27's Avatar
Default concerned motor swap.
just curious if theres anything i need to be aware of im changing my ls6 383 to a ls3 418. curious if oil pan will bolt back up. will parts interchange. is there any main pointers or concerns i need to know.? thnaks
Old 03-21-2013, 02:14 AM
bww3588's Avatar
The oil pan will fit no problem. But you will need to get a windage tray spacer kit to clear the crank. Also depending on the timing set, you will need an Ls2 front cover with a cam sensor and extension harness.
Old 03-21-2013, 06:11 AM
USMC5811's Avatar
i used some washers stacked together to clear the windage tray...just an idea!
Old 03-21-2013, 07:06 AM
87silverbullet's Avatar
Same here. I would already assume that you know you need a new intake for the rectangular port heads if you don't have one.
The LS2 front cover will a PITA if you use a double roller chain. The boss for the bolt that holds the cam sensor in place will hit the timing chain and you will end up grinding the **** out of it.
Old 03-21-2013, 07:14 AM
bww3588's Avatar
That will work as well.
Old 03-21-2013, 04:48 PM
ws6guy27's Avatar
Already getting intake and stuff for it.. and its a doubke rollmaster timing chain.. so idk what kinda cover is on it exactky.. the car been running in guys car for while...
Old 03-21-2013, 05:07 PM
Bowtie316's Avatar
Is the LS3 set up with the correct reluctor wheel on the crank?
Old 03-21-2013, 09:54 PM
ws6guy27's Avatar
yes 24x..
Quick Reply: concerned motor swap.
