Who has steamrollers on there firebird/TA or camaro?
Old 03-23-2013, 03:57 PM
chasenovo's Avatar
Cool Who has steamrollers on there firebird/TA or camaro?
looking for some 315 tires for a 98 formula firebird ws6
i dont know what all you have to do to get them to fit/ do i need to get wider rims? anyone have some nice rim/tire combo forsale they arnt using? some nice pic? how they mounted?
Old 03-23-2013, 04:06 PM
chasenovo's Avatar
sorry i have the stoxk ws6 rims. 17inch i think 9.5 inch wide? i think.
carlos64030's Avatar
For a 315, you should use 10.5" - 11.0" wheels and roll the inner fender lip. Getting wheels with the right offset is pretty important.
Old 03-23-2013, 08:36 PM
Streetlegal?'s Avatar
I have c5 DD 18x10.5 in the rear with 315s. You are going to most likely have to do the BFH mod so they don't rub. I plan on rolling my fenders too as an added precaution.
Old 03-23-2013, 08:43 PM
LPE 403's Avatar
315-30/18 on 11s. Cut stops, BFH'd (slightly) and rolled fenders. Offsets are perfect but wasnt taking any chances
Old 03-24-2013, 01:32 PM
dailydriver's Avatar
Are you looking to put 315s ALL AROUND, and not the 'staggered' setup soooo common/popular on here??
If so, go over to frrax.com, since everyone autocrossing in E/SP class, and those allowed by the rules to run 17" diameter wheels in road racing are ALL running that setup on their rides, on ALL corners.
Old 03-24-2013, 01:45 PM
lemons12's Avatar
I have 325s on mine...
BFH roll fenders cut stops
Old 03-24-2013, 01:56 PM
bayer-z28's Avatar
My buddy had 315's on all 4 with 17 x 11 TT2's. Overly common wheel, but it worked really well. His car felt like it was on rails.
What are the BS OS recommendations for rear 315's on 10.5 or 11's?
Old 03-24-2013, 02:59 PM
JimMueller's Avatar
My daily driver has NT-05 315's all around with ZR1 11x17 50mm replicas. I have 1/4" 6061-T6 hub centric spacers F&R. Rear also has BFH mod and tubular control arms. That works OK for V710's and A6's because the outer shoulder is rounded.
For street tires with square shoulders, it needs a bit more on the FR as on hard left lock it barely rubs against the sway bar arm. Rear also needs fenders rolled due to shoulders.
I'm swapping front hubs 1-2x per year, getting about 1.5-2 years per set of tires at < 1000 miles per month. Getting about 10-12MPG in the city but not trying for fuel economy. Tramlines badly on poor pavement and hard to get the tires hot compared to a narrower tire. But damn it's fun
Old 03-25-2013, 01:52 AM
JDEP162's Avatar
is it bad that when i see this car i get slightly aroused???
btw thanks for the pic of that fender rolling tool always wanted to see it in action, makes sense now
Old 03-25-2013, 08:33 AM
Old 03-25-2013, 09:34 AM
Mr. Trick's Avatar
I have 325s, rolled the fender lip and did some bfh on the inner wheels wells and have an adj panhard bar, I did not have to cut the bump stops
Old 03-25-2013, 10:09 AM
YURVIEW's Avatar
LPE, you Need to put some Wax on that paint, bub. I cant Quite see the color of your Eyes!! Beautiful man, beautiful
Old 03-25-2013, 06:38 PM
Tire Smoking Tranny Blowing Director
Cool28's Avatar
Here's some 335s not tubbed on fender rolled. When I lower it ill probably have to tub and fender roll though
Here's 295s up front on 18s
Old 03-25-2013, 06:41 PM
Cool28's Avatar
For the rears had to remove the bump stop and beat the hell out of the inside fender well.
Fronts when it turns was rubbing on the bottom of the wheel well so my shop fabbed it up so the well turned in on the bottom so it doesn't hit. Can get pics if you want when it's out of the shop for exhaust install
Old 03-25-2013, 06:55 PM
MasterTomos's Avatar
'95 Formula with 315's on 17x11" ZR1 wheels. BFH a touch and trimmed bump stops. Please excuse the fact that it's dirty
Attached Thumbnails Who has steamrollers on there firebird/TA or camaro?-314689_10150477500765460_330738202_n.jpg
Old 03-25-2013, 06:56 PM
RAMPANT's Avatar
I run 4 17 x 10.5 TTMs with 315s for autocross and track days.
The rear needed a little BFH mods and I wanted to keep the bump stops so I moved them in board a little. Plus I rolled the fenders. On the front I added a couple screws to the plastic inners fenders to hold them out better and off the tires.
Old 03-25-2013, 07:26 PM
LPE 403's Avatar
Thanks guys
Originally Posted by RAMPANT
Nice work as usual Dale!
Old 03-27-2013, 07:23 AM
RAMPANT's Avatar
^^^^Thanks^^^^
Not as nice as yours, but for something I beat on it looks pretty good.
Woodward this year!!!!!
Old 03-27-2013, 10:08 AM
Rise of the Phoenix's Avatar
325/30/20's on my WS6.
Attached Thumbnails Who has steamrollers on there firebird/TA or camaro?-ls1tech.jpg
Quick Reply: Who has steamrollers on there firebird/TA or camaro?
