T56 reverse
T56 reverse
Hello everyone, just wanted to introduce myself and at the same time ask 2 basic questions.
My car is a 68 Camaro with a BB 454 all cast (yes even the heads lol) and I am primed to take out 685 bls of steel to possibly drop an L92 engine from a '10 escalade. I think I'll be shaving about 250 lbs off the nose. Would that be a good estimate?
Last weekend I purchased a T56 but as I was shifting it I can't seem to put it in reverse. I was wondering if there is some kind of electronic lock that makes it impossible to put it in reverse while it's sitting on the floor. Or is there something wrong with my tranny?
I have a B&M shiffter on it right now.
Thanks for your input!!!
Thanks for the reply.
There's the solenoid which opens the reverse gate. Otherwise there's a big mean spring in there. You can "crash" through it in the event of a solenoid failure but you have to push kind of hard. Some people leave it that way. I found it real annoying.
When you wire it up, a lot of people either use a shifter with a button, or like I did on my Monza, wire the solenoid into the brake light circuit. (just "t" it in) Tap the brakes, easy shift to reverse. Just remember to wire in a diode on the lights side of your splice or the back feed from the lights will leave the solenoid on when the headlights are on.
Here's a thread where a few fellas were taking the solenoid apart and replacing the big spring for a lighter one. I suppose that would be an option as well.
http://www.svtperformance.com/forums...-solenoid.html
I just swapped a T56 in to my iroc. I didnt like the idea of having it wired to my brake switch. That means ever time I go to downshift while on the brakes, i run the risk of shifting into R by accident. I wired mine to a toggle switch. It works great. The lockout simply has 2 wires, one for 12 v one for a ground.
I did the same thing when I t56 swapped my gt, If you don't want to run electricity to it look in mustang forums for info on replacing the 2 springs with one that is lighter so it will be easier to put in reverse manually, I did the toggle switch because I was too lazy to pull mine apart
When I have the Monza back on the road It'll be MegaSquirted so I'll just wire up and configure an output to turn on under 5 mph like the factory computers do.
