General LSX Automobile Discussion Non-technical LSX related topics.
I wanna go faster-consistently
Old 03-30-2013, 10:25 AM
tjwashow's Avatar
Default I wanna go faster-consistently
i wanna be able to mash the pedal from a stand still-hook-and go consistently.
what do i need?
Old 03-30-2013, 10:39 AM
ULTIMATEORANGESS's Avatar
tires will help big time.
Old 03-30-2013, 10:45 AM
tjwashow's Avatar
true i have been hearing this lol, i guess whaty i am looking to know besides the tires, is what it takes or what does one person need to buy in order to be "DIALED IN" so to say.
Old 03-30-2013, 10:57 AM
MonmouthCtyLS7's Avatar
MT Dr's and some rear suspension.....
Old 03-30-2013, 11:55 AM
you can add a torque arm.LCAs,brackets. panhard rod.
what trans do you have?
Old 03-30-2013, 12:26 PM
tjwashow's Avatar
i have an auto 4l60e. I am getting the suspension shored up this summer, I will be ordering the PHB and LCA's and lca brackets from founders next month, at right around 170 for all of that. I dont think i will be getting adjustable as i dont really wanna lower anything. I know to really hook i need DR's, maybe ill get some but im sticking with street tire for now.
I am also getting some UMI bolt in SFC's for a hundred. with the addition on the LCA stuff and PHB that pretty much takes care of the rear for me, minus sway bar. However, I fear my real problem is the stock worn out decarbons. I will be buying some new shocks before anything else is bought. I will be getting a 3800 stall as well. probably revmax. flame on.
Old 03-30-2013, 12:53 PM
get some konis. what a difference they make.
Old 03-30-2013, 01:42 PM
Cra-Z Larry's Avatar
Remove the front swaybar, adjustable shocks, torque arm and MT DRs. That should get you hooking alot better! Don't worry about the rear swaybar just yet, get the other things first! And what's up with the 354hp @ 5400rpm, don't tell me it falls off after that!! Do you have the stock LS1 intake??
Old 03-31-2013, 10:59 AM
ds98formula's Avatar
Stall first if you are on stock stall
Old 03-31-2013, 04:48 PM
lt1 sport's Avatar
drag radials, comp engineering drag shocks out back, double adj qa1's up front. Dead hook every time with a 3200 stall. Everything else is stock.
Old 04-01-2013, 09:06 AM
tjwashow's Avatar
will removing the front sway drastically change handling for a dd? Whats the purpose of removing the front sway bar?
Yes I have the stock ls1 intake! But the 5400 is becasue we didnt take it that high in 3rd gear, something about dynoing a 98' and with their steel driveshafts snapping tail housings when you get to 125 mph plus and just let off the gas. I wanted to make sure my a/f were spot on and the guys over at straightline helped me big time. Its probably a safe tune but we predicted about 370 whp at 62-6500. I need an ls6 intake tho i am aware of this. It was still climbing at 5400 tho. ill try and get a pic of my graph.
i am thinking of getting rear drag shocks and getting some adjustables in front. shouldnt compromise handling right? i dont autocross. i am definitely in need of a stall.
I dont really wanna add more hp just lookinging to get my current setup dialed in.
hey what color is that car in your sig? i am in need of paint and was looking for a color green around there.
Old 04-01-2013, 10:16 AM
Never heard of anything breaking from letting out at 125 mph on any year I have a 98 and spun it too 6300 on the dyno both bolt on and when cam went in
Old 04-01-2013, 11:48 AM
tjwashow's Avatar
ds neither did I! thats why i was a little confused, speed inc told me steel driveshafts dont like dyno's, and told me a horror story about a guy just brought his 98 auto in there and broke his tail housing. I believe this is in reference to autos and not your 6spd. I could have pulled higher but would of been number hunting at that point. Once i get an ls6 intake on there ill spin her 6500 and see where im at at that point.
Old 04-01-2013, 12:12 PM
removing your front sway bar is for better weight transfer. id reinstall after racing.
get your car redynoed. i never heard about a steel DS breaking for no reason. but if it was me id go with an aluminum DS.
Old 04-01-2013, 02:10 PM
1320Chicken's Avatar
I can't see where that's the ds breaking the tail shaft. Maybe the tq if it has an excessive amount of preload. I let out in the 125 range more often than not at the track and have had no issues what so ever.
Back to the topic though a tire would be first on the list. If the tire isn't going to hook the suspension isn't going to get a chance to work.
Old 04-01-2013, 03:06 PM
mjs1012's Avatar
get a converter, good tire, and practice
Old 04-01-2013, 03:56 PM
Mine is not a DD but I do drive it wherever I go. QA1s w/275# springs on the front, no swaybar, skinnies, MT DRs and a spool. If your car is setup for drag racing then drive it accordingly!!! I have heard of stock TAs breaking the tailshaft at the mounting point, install an aftermarket TA or at least the bracket that mounts the stock TA to the crossmember. You better get the car to hook before adding more power or a big converter, wheelspin leads to wheelhop which leads to a broken rear!!
Old 04-01-2013, 06:58 PM
If on stock stall that is for sure the best mod to do next. In an auto it should be the first mod
Old 04-01-2013, 07:29 PM
justin hover's Avatar
^^^^yup..If I'd of know that when I first bought my car...It would've been my first mod.. What a difference a stall makes. Your running a 224 without a suitable stall???? Why?? No brainer here... 32-3600stall would love that cam, and help you go faster...match it with some sticky tires. This is just too obvious here.
Old 04-01-2013, 07:42 PM
senicalj4579's Avatar
Yeah you need a stall. 3200-4000.
I would prefer a aluminum DS.
If i'm trying for a personal best I race without the swaybar but I re install it for street. I dont like the feel without it.
You def need a good tire for consistancy.
Suspension is always a plus even though I have none.
Quick Reply: I wanna go faster-consistently
