Power Steering Whine?
Old 04-06-2013, 02:59 PM
mhugney's Avatar
Default Power Steering Whine?
I've got a 2000 camaro with some serious whining coming out of the engine. I first notices it while I was driving, and it seems to be worse while turning (leads me to think its the power steering, but to be honest I'm 17 and not very knowledgable). However, i can here it while the engine is idle and im looking at it. The belt seems to be vibrating near the bottom of the engine, do you guys think the belt is loose, or is it something else?
Old 04-06-2013, 03:35 PM
ZouMechE's Avatar
Check your power steering fluid level
Old 04-07-2013, 08:34 AM
Save the manuals!
wssix99's Avatar
That would all be consistent with a power steering system issue. (Pump or rack.) As mentioned above, start with the fluids. If you are low, you'll get a whine. Doing a flush of the fluid may also get rid of the noise if the system isn't too far worn. Has it been like this for a long time?
Not sure what this is. Maybe you can post a video?
Old 04-07-2013, 12:19 PM
mhugney's Avatar
As far as the fluid, I checked it and it is getting low, I guess i never imagined it would produce a whine, thanks. As far as the vibration, I'll add the fluid and if it isn't fixed then I'll post a video. Thanks again.
Old 04-07-2013, 12:27 PM
mhugney's Avatar
Anyone know what power steering fluid is best to use for the car? (2000 Camaro V6)
Old 04-07-2013, 01:58 PM
It's not mine! woo hoo!
demonspeed's Avatar
I use Valvoline, but I'd not hesitate to use the store brands. I'm sure others will say to use some sort of hi-temp racing formula, but... that's probably overkill for your application.
Old 04-07-2013, 07:54 PM
ZouMechE's Avatar
Keep an eye on the fluid level for a few weeks after you top it off to make sure you don't have a leak or something
Old 04-07-2013, 10:01 PM
mhugney's Avatar
I do have a leak, and I've identified the hose, do you have any idea which it is? You can see it at the top of the screen shiny (wet) with a drop about to fall. the picture is taken from underneath the car from the front. the boot seen is over the inner tie rod
Old 04-07-2013, 10:59 PM
Save the manuals!
wssix99's Avatar
That's probably the pressure hose. It's always the first to go.
Old 04-08-2013, 09:05 AM
demonspeed's Avatar
Yes, that appears to be the pressure line. ACDelco 36-363170 $30 shipped from Amazon
You might also want to consider this: https://ls1tech.com/forums/general-m...g-success.html I was just going to change my pressure hose when I said "eff it" and did the aftermarket cooler and added the upper radiator hose from a '98 Z28.
Old 04-08-2013, 10:28 AM
Save the manuals!
wssix99's Avatar
Its a V6, so it would not have come with a stock cooler.
Quick Reply: Power Steering Whine?
