Procharger guys 8 rib pulley question
Old 04-09-2013, 07:13 PM
ross02ss's Avatar
Default Procharger guys 8 rib pulley question
So I'm running a d1sc on my 01 camaro. I have a 3.40 pulley on the head unit now. I'm trying to find a smaller pulley since that is the smallest procharger sells. I herd pulleyboys but my coworker just bought one from them and it didnt fit.
Anyone know of a place that sells smaller then a 3.40 8rib?
Would be nice if its a direct fit!
Sorry if this has been covered before but I couldn't find any old threads with information on this.
Thanks
Old 04-09-2013, 07:26 PM
js2fst's Avatar
Reinhard
Old 04-09-2013, 07:46 PM
ross02ss's Avatar
Thanks man
Old 04-09-2013, 09:05 PM
js2fst's Avatar
Reichard sorry auto correct
Old 04-10-2013, 06:16 AM
stealth355tpi's Avatar
Depending on your redline rpm you might already be spinning the blower to its max speed.
Old 04-10-2013, 10:05 AM
ross02ss's Avatar
I'm only spinning it to like 52000 . A 3.1 blower pulley will put me right at 62000 on the blower. But I can't seem to find one.
Called lethal performance and the told me reichard has some military contract that he can't get them for fbody.
So maybe I can come across a used one
Old 04-10-2013, 10:26 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
What size is your crank pulley? I'd be worried about belt slip going smaller than 3.4".
Old 04-10-2013, 10:43 AM
ross02ss's Avatar
7.625 crank pulley 3.4 blower pulley. I just looked at the chart again since its been awhile and at the rpm were pulling the car to the blower is at 57008.
With a 3.1 ill be at 62525.
And I have thought about belt slip but I herd those Reichard pulleys don't slip much and I have a gator back belt that is to small for my current setup . Should b perfect if I can get a 3.1
Old 04-10-2013, 12:00 PM
UNDER PRESSURE MOD
Wait, how low of an RPM are you spinning your motor to?
7.625" / 3.4" * 4.1 (internal step up ratio) * rpm (6500 for an example) is 59,800 rpm.
Honestly, I'd rather spin a motor a little higher than to go to a small pulley that needs to be custom made.
Old 04-10-2013, 12:32 PM
ross02ss's Avatar
6200 rpm. For some reason the blower has never made power past that. Been on 3 dynos and no sign of belt slip.
After the second dyno my trans was getting some slip and we thought that could b why. But brand new tranny now and still it stops making power at 6200 rpm. So that's were we left it
Old 04-10-2013, 12:35 PM
ross02ss's Avatar
If the blower would still make power I would love to just pull the motor higher n the rpms
Old 04-10-2013, 01:59 PM
conan's Avatar
You could throw a 8'' crank pulley on there witht the 3.4" and that will get you to 62,800 blower rpm @ 6,500 engine rpm
Old 06-26-2013, 04:40 PM
Firehawk441's Avatar
Who makes an 8" crank pulley for the F-Body?
Old 06-27-2013, 03:27 PM
conan's Avatar
I thought I read a thread a while back that bob used one on a build at the old EPP. I'll see if I can find it or maybe bob will chime in...
Old 06-27-2013, 03:35 PM
25thhawk's Avatar
Try Innovators west. They make them for the vettes. I'm sure they can make one for an f-body.
Quick Reply: Procharger guys 8 rib pulley question
