Low or high imped?
Old Jun 27, 2013 | 06:09 AM
69-chvl's Avatar
Default Low or high imped?
Given the choice between the 2, what's the better injector to run for a mostly stock 5.3, mostly on the street? Bene's/neg's would be nice. My EFI system will run either. Looking at Siemens 83lbs for around 350.00, or Holley low imp for around 400.00. Thanks!!!
Old Jun 27, 2013 | 06:28 AM
stock48's Avatar
9 Second Truck Club
I have the same simmens high Z 83's and they work well with my holley efi on both e85 and gas. The low Z botch injectors I have will surge at idle no matter what I do. Just ordered fic 2000's and haven't had time to try them yet.
Old Jun 27, 2013 | 12:15 PM
69-chvl's Avatar
Thanks.
Are you saying the low z will surge with the Holly efi? What size are they?
I'm leaning towards the Siemens, but some say the low z are better, but others say the newer z injectors are as "fast" as the low z jobs.
Old Jun 27, 2013 | 02:53 PM
stock48's Avatar
9 Second Truck Club
Im not sure about the low Z surging in the 80 lb injector but there is a good chance the 160's will. The holley is a really picky system at idle. Im still learning with it so maybe someone with more experience could make the 160's work. I can just say they wern't working for me and the sim 83's work perfect.
Old Jun 27, 2013 | 03:56 PM
chiaj144's Avatar
I have the Holley 120's. They work great on my 5.3 with both pump gas and E85. No surging idle. I did have a surging idle before I got the tune dialed in.
Old Jun 27, 2013 | 04:14 PM
stevieturbo's Avatar
The modern Siemens, Bosch, ID or whatever 83lb or similar sizes are well proven injectors.
I'd choose them over the older spec lowZ stuff any day.
Old Jun 27, 2013 | 05:02 PM
69-chvl's Avatar
chiaj144, would you say they idle as good as a smaller injector? Are you also running the Holley EFI?
Old Jun 27, 2013 | 08:31 PM
chiaj144's Avatar
I'm running a Holley HP. My car idles like a stocker even on pump gas. I was worried that they would be too big.
Old Jun 27, 2013 | 09:22 PM
stock48's Avatar
9 Second Truck Club
What rpm is your idle?
Old Jun 27, 2013 | 09:29 PM
chiaj144's Avatar
850 from 160* and up.
