Bumping timing up 2.5 degrees
Old 04-11-2013, 07:24 PM
CAMJAG's Avatar
Default Bumping timing up 2.5 degrees
Is it safe to bump the timing up 2.5 degrees on my 03 Z06 with 93 octane? There is a Sunoco station not far from where I live that sells 260 GT 100 octane (oxygenated, unleaded). http://www.racegas.com/fuel/17 I am looking to lower my ETs as much as possible. I am dragging the car this weekend. Can it be done with straight 93 pump or should I run half 100 half 93 in the tank?
Your basic stock LS6 with a Vara Ram & power duct, high flow cats, X pipe & B&B bullets
I am embarrassed to say I am using a Crane Cams tuner because it was given to me from a friend and that is what I am using to add timing. The tune is also on the “High performance stock cam”
Old 04-11-2013, 08:05 PM
lemons12's Avatar
Can't answer that question without knowing what the timing is now.
Also, is it worth 4rwhp if it causes an unsafe tune?
Old 04-11-2013, 08:15 PM
CAMJAG's Avatar
I have been done some searching here for the last two hours. Pretty much what I came up with was the question I asked. A higher octane is beneficial when adding more timing and using the higher octane makes it safer? I just want to see if my research is correct. I know its hard to tell without the numbers. I am just using this tuner that was given to me and supplied all the info I could.
Old 04-11-2013, 09:34 PM
baileydirt27's Avatar
Well would the knock retard not take the timing away if it was too much? Hopefully someone with more experience can confirm that.
Also going with a higher octane may cause you to lose power if you dont have the timing high enough. Honestly I wouldnt worry with it since you cant get it dialed for sure before you go.
Old 04-11-2013, 09:58 PM
outkast6991's Avatar
If adding timing induces knock then the sensors will pull timing till it clears up. It is still possible to have more timing than is necessary without reading kr though. If your making hits at the track make a couple passes with it where it's at and then a couple with the added timing. If the car picks up then you know if its worth it or not
Old 04-11-2013, 09:59 PM
lemons12's Avatar
Sorry i was thinking still on 93.
You should be able to pick some up and still be safe.
Im motor even a starter when it comes to tuning however.
Old 04-11-2013, 10:48 PM
minytrker's Avatar
2.5 deg's higher than stock, yes. 2.5 deg's from unknown mythical number, no
Old 04-12-2013, 06:38 AM
edcmat-l1's Avatar
LS6s don't want or even like a lot of timing. If you're at optimum, adding won't do anything, even with higher octane. That being said, if you're below optimum, adding a couple degrees won't hurt, and might help a little bit.
Old 04-12-2013, 08:07 AM
HioSSilver's Avatar
My ls6 is @ 29* when I'm wot.
Old 04-12-2013, 12:46 PM
edcmat-l1's Avatar
That's a lot for an LS6.
Old 04-12-2013, 07:10 PM
BLK02WS6's Avatar
The only way to really know is to put it on a dyno to see if it makes more torque/power with more timing... otherwise, you are just guessing...
Old 04-12-2013, 09:01 PM
64post's Avatar
28* total, how SOON it gets it is the question, 12.8 A/F ratio, the 2 seem to work well together. Of course it will depend on altitude and humidity etc..
Old 04-12-2013, 10:20 PM
HioSSilver's Avatar
I've had others tell me that. But that's where it made the most power.
Old 04-12-2013, 10:42 PM
minytrker's Avatar
That seems like alot
I have never seen a single ls6 make the most hp at 29 out of all the ones I have had on the dyno. 26-28 seemed to be the average on every one of them. Anything above 28 and they never made anymore power. Was this on a loaded dyno or inertia?
Old 04-12-2013, 10:47 PM
HioSSilver's Avatar
Loaded. Dyno Dynamics.
Quick Reply: Bumping timing up 2.5 degrees
