copo replacement engine build
Old 05-02-2013, 02:57 PM
zacht's Avatar
Default copo replacement engine build
hey, first off...i dont have one, just came across this article.
http://www.dragzine.com/news/katech-...lus-horsepower
reading through it, they're building a 327 whipple...says 4.065 bore on LSX block. but my question is regarding the bore and the heads. says they are running GMPP LS7-LSx heads. says 2.205 intake valves, and replaced the hollow stem exhaust valves with stainless....1.615 exhaust.
when i look up the LS7-lsx heads (6 bolt) says valve sizes are 2.200/1.610, and they also say minimum bore of 4.100.
http://www.chevyhardcore.com/feature...ylinder-heads/
im just trying to figure out how all this went together, and if maybe some numbers are skewed a little....to me...seems like they got the heads (for minimum 4.100 bore) then put in bigger valves...and threw them on a 4.065 bore.....something is off...either the bore isnt 4.065, valves arent that big...wrong minimum bore stated....idk...numbers dont add up.....i can see some small bore LS7's working....dont know what to think i guess....
Old 05-02-2013, 06:46 PM
Jimbo1367's Avatar
IIRC....... they got that displacement by destroking it.
Old 05-02-2013, 08:29 PM
Driyac's Avatar
Word has it that they are blowing rear seals about every 10 passes...
Old 05-03-2013, 12:31 AM
zacht's Avatar
Ok..thanks....any words on the bore/head combo?
Old 05-05-2013, 06:49 PM
zacht's Avatar
anybody??? someones gotta know...katech should know!!!
Old 05-06-2013, 07:36 AM
LS1TECH Sponsor
Katech_Jason's Avatar
They are LSX-LS7 heads and the bore is 4.065". We clearanced the bore to make them work. The valves are 2.200/1.610". It looks like the author took the numbers from the COPO rules which allow for .005" oversize.
Old 05-06-2013, 07:42 PM
zacht's Avatar
so...basically what your getting at is the LSX-LS7 heads minimum bore is 4.065? not 4.100?
Old 05-07-2013, 07:39 AM
LS1TECH Sponsor
No, it's still 4.100". We just modified the block to make them work.
Old 05-09-2013, 11:34 AM
zacht's Avatar
ok cool, can you post up any information/ pics on this? i imagine its valve reliefs into the block, what do you do for a head gasket and such??? does this pose any problems??? (kinda thinking not, beings it cranked 1100+hp..)
Old 05-09-2013, 12:58 PM
LS1TECH Sponsor
Yes, valve reliefs in the liner. It's very minimal and does not affect the head gasket.
Old 05-11-2013, 02:51 PM
GoatPilot87's Avatar
Jus read that first article...damn. 172mm throttle body! Wonder if these engines will be worth bundles like the old zl1 is now in in forty years?
Old 05-13-2013, 07:57 AM
LS1TECH Sponsor
The throttle body is oval - 172mm wide. The article didn't specify that.
Old 05-13-2013, 10:19 PM
Ok got ya. Anyway...very cool guys.
Quick Reply: copo replacement engine build
