My Cam Kit
My Cam Kit
Update: Now a build thread.
400whp isn't cutting it, so I'm finally going to put a cam in my car.
EPS 234/236 .629"/.629" 113 LSA+4 spec'd by Pat G
BTR 3/8 7.425 Chomemoly Pushrods
Comp Cams Rocker Arm Trunion Upgrade
BTR .660 Dual Spring Kit with Titanium Retainers
TSP Ported LS6 Oil Pump with new O-ring
IWIS Timing Chain
TSP Basic Camshaft Bolt/Gasket kit
Powerbond 25% Underdrive Pulley with new belts
Overdrive Alternator Pulley
Injector Dynamics 1000cc
Deutsch Werks Fuel Pump
What am I missing that I still need to buy?
IWIS Timing Chain
We've established my car is slightly stronger than your average GTO. I don't know many other GTOs with coated stepped headers and a FAST 102 on the stock cam. Somehow, because I made a whole 10-15 hp over a ported LS2 intake and pacesetters the dynojet reading is fake. This is the same Dyno that read 317whp stock with a hacked crapmaster exhaust and 365whp Intake/Exhaust/Tune. If you want to accuse Lethal Performance SATX of bullshitting the number be my guest.
It really doesn't matter, the car makes power. Yes there's variation between dynos but do you think it's a 20hp standard deviation? Whenever somebody posts up a dyno number that's slightly higher than average people always say the dyno must have been rigged. Doubt it. Forget what's actually in my setup. Look around there's a thread here with a 415rwhp LS6 Z06.
