What aire pressure should I run?
Bought some new used wheels and tires 16x8 OE chrome 5 spokes,
The tires look good. They are 245 50 16 Hankook Ventus HRIIs. They say max PSI of 44. I read that usually you want to run about 90% of max PSI.
What PSI should I run them at?
Street use. Spirited driving. Stock F41 suspension except for 32mm front and 19 mm rear sway bars with energy suspenson bushings.
Thanks!
Thanks!
Usually a good starting point is what the vehicle manufacturer recomends. Try looking in the drivers door jamb. I think i'm running 30 all the way around or 32ish
