Help with installing new window motor
Old 05-14-2013, 02:50 PM
PSnewbie's Avatar
Default Help with installing new window motor
I am currently installing a new window motor on a 98 Camaro and the old motor is completely shot, I can't even get it to move the window up with help so I think the wiring is shot. As soon as I plug the new motor in to check it continuously runs without input from the switch and if I press the switch for up all that it does is stop the motor while pressing the switch for down does nothing. I'm sure this is a shorted wire, but the harness looks intact. can a bad switch do this? Thanks. -Rich
Edit: I am working on the driver side and I tried an old switch panel from a prior car and the motor does the same thing. I am more confused, does the window motor go through a bcm?
Old 05-14-2013, 11:02 PM
LoneGunman's Avatar
Where did you get the motor? Sounds like you might have gotten a bad one.
Old 05-14-2013, 11:12 PM
RJDio's Avatar
It did sound like a bad switch, good thing you had one to test with. Are you testing the motor under load? If not, Try mounting the motor in the door, then try using the switch and allow the motor to hits it's load in it's stops up and down. If it works like the headlight motors, they turn off when they sense the load on the motor since there is no limit switches.
Old 05-15-2013, 03:48 AM
PSnewbie's Avatar
I only tested the motor in a no load situation. I also know that according to this video: http://www.youtube.com/watch?feature...syVzfN4#t=639s, the motor should only function while the switch is pressed. Thinking that I have a wiring problem I tested the wires for the driver's switch and at any given time with no motor or switch attached all 3 wires are hot. This has me stumped. Thanks for the replies btw way guys, I appreciate it.
Old 05-15-2013, 07:00 AM
Save the manuals!
wssix99's Avatar
+1
This happens a lot with reman motors. They can have a bad cutoff switch in side and shut down when under load. (Just like they are supposed to when the window is all the way up.)
If you go with a doorman motor, it will be 100% new and should last longer with the updated design.
Old 05-15-2013, 12:01 PM
Chevyguy2001's Avatar
Whats the best window motor you can get???
Old 05-15-2013, 02:28 PM
PSnewbie's Avatar
I have a new unit, not a dorman though.
Old 05-15-2013, 02:30 PM
PSnewbie's Avatar
The motor runs fine, my car is sending it power when it shouldn't be.
Old 05-15-2013, 02:37 PM
sick_tight's Avatar
unless all the switch does is provide the ground for the circuit. then it could cause the motor to go up continuously if its shorted or internally shorted. i dont know how the wiring is on the windows
Old 05-15-2013, 02:49 PM
Save the manuals!
wssix99's Avatar
Even if the parts guy told you it was new, its probably not. Lots of threads on this. (The part was first installed on a GM car between 1967 and 1969.) Its probably a reman with "new" parts - except for the thermal resistor, which is failing on you.
It runs fine unloaded until it encounters a load and the thermal resistor (cut-off circuit) engages. Odds are, its probably still bad. (I've had 2 fail on me this way - right out of the box.)
It doesn't. The motor gets positive/ground and the switch reverses polarity to change the direction of motion.
Old 05-15-2013, 03:44 PM
sick_tight's Avatar
i think my passenger window motor is on its last leg as well, its gotten progressively slower and now today the thermal fuse keeps cutting it off and it only moves a half inch up or down
Old 05-15-2013, 09:04 PM
PSnewbie's Avatar
I've haven't installed in yet to the point of the motor having a load on it, the thermal resistor may very well be bad, but it hasn't shut the motor off as of yet. I've only had the motor plugged into the harness for a few seconds at a time to try and check the wiring for shorts.
Also, I just got done pulling the bcm and the 3 wires to the window switch were no longer all hot, they were obviously dead since the circuit was broken. Does this mean that the problem is in the relay in the bcm or not? Thanks again guys, appreciate all the responses.
Old 05-16-2013, 12:10 AM
Save the manuals!
wssix99's Avatar
Sorry, I misread your OP. (I missed that the motor is running w/o pressing the switch.)
If the motor runs by itself, it could be the switch or express down module. An easy check would be to offset the harness on the driver's side switches so the passenger switch is hooked up to the driver's side circuit. That should isolate the switch to see if its the problem. (I'm pretty sure you can do this but its been a while since I had the occasion to remove my switches.)
Old 05-16-2013, 02:01 PM
PSnewbie's Avatar
I've already tried 2 other switches that I happen to have and they all do the same thing. As soon and the switch contacts the connector the motor turns.
Does that pretty much mean it is the Express down module?
Old 05-16-2013, 05:47 PM
Save the manuals!
wssix99's Avatar
The EDM is really expensive - even used, because people buy them to add EDM to the passenger side of the car. So, I'd confirm its the EDM first by unplugging the module and bypassing it at the connector. Whitebird00 describes how to do that in this thread: https://ls1tech.com/forums/stereo-el...ress-down.html
Once you bypass the module, the drivers' switch and motor should work just like the passenger side.
Old 05-23-2013, 03:14 AM
PSnewbie's Avatar
I followed WhiteBird00's super easy instructions:
Originally Posted by WhiteBird00
The left window is wired differently because of the express down module. You'll have to bypass the module in order to do what you want. You can bypass the module by simply connecting the gray wire to the brown output wire at the express down module. Make sure you get the right brown wire - there are two of them. The one you want is pin D in the connector. The one you don't want is pin C in the connector and will have power whenever the ignition is on so it's easy to find with a test light or multimeter.
and now my motor works just fine! It goes up and down like it should. I don't know who to thank for the EDM bypass info so I'll thank you both, lol. Thanks guys!
Quick Reply: Help with installing new window motor
