'01 Z28 donor - LS1 RWD HHR Panel
Old 05-16-2013, 11:06 AM
lasater's Avatar
Default '01 Z28 donor - LS1 RWD HHR Panel
I'm in Riverside CA. I'm converting an '08 HHR Panel to rear wheel drive using a '01 Z28 as a donor. Will be having lots of tech questions soon.
<a href="http://s1248.photobucket.com/user/vwstreetrod/media/071_zps2zzjl81t.jpg.html" target="_blank"><img src="http://i1248.photobucket.com/albums/hh493/vwstreetrod/071_zps2zzjl81t.jpg~original" border="0" alt=" photo 071_zps2zzjl81t.jpg"/></a>
The following users liked this post:
5.3Caprice (10-18-2019)
Old 07-21-2013, 11:52 PM
hugger1975's Avatar
Update?
Old 06-09-2014, 05:38 PM
lasater's Avatar
Default V8 HHR update
OK here is what I have so far. The drive train is almost finished, the brake and steering mods are almost complete. Still need to tub the rear wheel wells and drive shaft hump. I'll be using the entire '01 Camaro wiring harness from bumper to bumper.
You can check it out on YouTube @ HHR V8 slideshow
Attached Thumbnails '01 Z28 donor - LS1 RWD HHR Panel-20131210_140817.jpg   '01 Z28 donor - LS1 RWD HHR Panel-engine-compartment.jpg   '01 Z28 donor - LS1 RWD HHR Panel-rear-suspension.jpg   '01 Z28 donor - LS1 RWD HHR Panel-frame-2.jpg   '01 Z28 donor - LS1 RWD HHR Panel-tires.jpg
Old 06-10-2014, 10:15 AM
It's not mine! woo hoo!
demonspeed's Avatar
Very interesting... I'll move this to the conversions section
Old 06-10-2014, 09:19 PM
murphinator's Avatar
older engine with more cylinders than the vehicle came with in Cali??? hoping you know what loopholes will get it through smog
Old 07-16-2014, 03:07 PM
lasater's Avatar
Yeah I know this will never be a "legal" car in California. The smog test won't be too bad.....not legal but not too expensive. Smog will only be 1 of the illegal things about this car. If it get to be too much of a hassle I will register it in Arizona.
Old 07-17-2014, 08:59 AM
idle's Avatar
This is badass! I owned an HHR SS for about 3 months and loved it to death! All my friends, coworkers, and families gave me a hard time about having a "PT Cruiser" but that thing had 300/330 and damn good steering. Glad to see someone putting an LS in such a neat platform!
So you went with the LS1/4L60E? Any modifications to them after that? Do you have more photos?
Old 07-23-2014, 06:28 PM
lasater's Avatar
Default Update Pics
Here are some more pics of the project. The engine is getting torn down now for a complete rebuild with heads and cam. The trans is in the shop getting a full rebuild, 2200 stall converter, Corvette servo and a shift kit.
Attached Thumbnails '01 Z28 donor - LS1 RWD HHR Panel-20140717_171035.jpg   '01 Z28 donor - LS1 RWD HHR Panel-20140717_171121.jpg   '01 Z28 donor - LS1 RWD HHR Panel-20140322_181806.jpg   '01 Z28 donor - LS1 RWD HHR Panel-20131213_133815.jpg   '01 Z28 donor - LS1 RWD HHR Panel-20140110_140357.jpg
'01 Z28 donor - LS1 RWD HHR Panel-20131222_144625.jpg   '01 Z28 donor - LS1 RWD HHR Panel-20130927_152841.jpg
Old 11-27-2014, 10:16 AM
lasater's Avatar
The work is progressing slowly. The trans is done, the engine will be done in a few weeks. The forward sheet metal section is done , now it's on to the wheel tubs and fuel cell install. I'll be installing the complete z28 wiring harness. Hope to have it running in the summer.
Old 11-27-2014, 10:53 AM
Tig
Tig's Avatar
Very cool and definitely out of the box.
Its going to be bad *** when completed
Subd
Old 12-04-2014, 09:44 PM
yooperLS6's Avatar
Very Cool, an advanced version of putting a sb in a vega wagon! Nice.
Old 01-22-2015, 08:39 AM
JustAnotherZ28's Avatar
Default Need my fix!
I need an update! I'm dieing to do this myself. I can't wait to see it finished!
Old 01-22-2015, 09:08 AM
M K S's Avatar
Nice! Interesting swap, waiting for more pics.....
Old 02-17-2015, 01:38 AM
lasater's Avatar
Default Engine done
Engine is completed. It goes in this week.
[/URL]
Old 02-17-2015, 10:17 AM
76larkman's Avatar
I like the car, also your work looks to be excellent. I clipped a hhr as it was a rollover. I ended up only using the dash foward & front structure. not much to these cars.
Old 02-17-2015, 10:41 AM
JustinEntropyRad's Avatar
Default um...
Hope you can find an '08 engine stamp..or know someone at a BAR station..doesnt the engine have to be the same year or newer out there?
Old 02-17-2015, 11:21 AM
static low 92's Avatar
Read post #6
Old 02-17-2015, 02:28 PM
Default Doh...
Good catch...
Old 02-26-2015, 08:58 PM
lasater's Avatar
Default Update
Spending time installing the engine wiring harness. Since I'm using the entire Camaro wiring, I'll be simply relocating some of the items such as the ecu and the bcm to new spots. Hope it isn't too difficult.
The engine is complete. Here is a breakdown of the engine build.
2001 Z28 5.7 block , complete machine service
New crank, rods, pistons, bearings, oil pump
Comp cam, Comp lifters, Yella Terra rockers and Manton pushrods.
Texas Speed PRC 227 heads
FAST 102 intake manifold with Nick Williams 102 throttle body.
Attached Thumbnails '01 Z28 donor - LS1 RWD HHR Panel-20150224_151935.jpg   '01 Z28 donor - LS1 RWD HHR Panel-20150224_151919.jpg   '01 Z28 donor - LS1 RWD HHR Panel-20150224_152021.jpg
Old 03-28-2015, 08:28 AM
lasater's Avatar
Default Drivetrain In !
The entire drivetrain is back in the car now. Sorting out thr the Camaro wiring harness.
Quick Reply: '01 Z28 donor - LS1 RWD HHR Panel
