Flex Fuel CTSV Dyno
Old 05-29-2013, 09:46 PM
1INSANEGTO's Avatar
Default Flex Fuel CTSV Dyno
Issues with the boost controller but ended the night with 680rwhp at 10psi but the boost keeps dropping back down to 8psi so going to get that issue fixed.
Impressed with the ethanol fuel sensor setup.
More to come....
Old 05-30-2013, 10:19 AM
1INSANEGTO's Avatar
O btw found my boost issue. Westgate lines melted lol
Old 05-30-2013, 01:54 PM
venom ws7's Avatar
LS1Tech 20 Year Member
Good numbers on this boost level now fix the leak and let it eat.
Old 05-30-2013, 02:06 PM
needaz28's Avatar
whats this ethanol fuel sensor setup? I just saw you post that in the 4.0 whipple thread. is this something I can use on a 02 f body ecu? ,ore details please
Old 05-30-2013, 06:10 PM
1INSANEGTO's Avatar
No sure if GM put it in those pcm's or not.
I keep having this issue! Now time for a bracket!
Did make a pull at 17psi. Needless to say at 6000rpm it makes almost 800rwhp
Old 05-31-2013, 10:05 AM
bttlfed98gt's Avatar
Nice fuel line!
Where does the westgate go?
Is there an eastgate on the other side?
Old 05-31-2013, 10:06 AM
http://youtu.be/101769X2NZs
Did make a pull at 17psi. Needless to say at 6000rpm it makes over almost 800rwhp
How the FUC* can you make over almost something???????
Old 06-01-2013, 12:36 AM
1INSANEGTO's Avatar
Huh???? As in I don't want to post a number lol
It's done....
Quick Reply: Flex Fuel CTSV Dyno
