stock ls1 guys, what temp does your car run with ac on?
Old 05-31-2013, 03:37 PM
SPRAYED 01's Avatar
Default stock ls1 guys, what temp does your car run with ac on?
This question is for stock or bolt on type cars with a totally stock cooling system.
With ac blasting in 90 plus temp, have you scanned your car to see what its at exactly?
Is 225 normal in traffic or stopped?
Old 05-31-2013, 04:11 PM
Mr Phil's Avatar
i dont have ac so idk hahaha
Old 05-31-2013, 04:57 PM
SPRAYED 01's Avatar
thanks dr phil. Never liked your show any way
Old 05-31-2013, 05:12 PM
senicalj4579's Avatar
When my car was stock with stock settings 225 would be nornal. I remember seeing 235 read from pcm.
Now my car is modded and is a sob....
Old 06-01-2013, 04:42 AM
NC01TA's Avatar
My 100% stock car's gauge always sits right in the middle and I know it can't be accurate. Once the car has warmed up the gauge shows the same whether it's 20 degrees outside or sitting in 90 degree Atlanta traffic. I've had the Dexcool changed out about 3 years ago, just due to age, and the new Dexcool did nothing to change the readings. What's the actual temp?? No idea.
Old 06-01-2013, 11:37 AM
'99REDTA's Avatar
There must have been bad gauges put into cars, because mine does a good bit of moving around telling me that it gives actual readings
Old 06-01-2013, 11:43 AM
Heres a little example of how bad the stock gauges are...My car had heating problems couple days ago. Stock gauge read just passed the half way mark while I read 242 from the pcm.
Old 06-01-2013, 12:06 PM
Blackpanther99's Avatar
That explains why your windows are down in your sig
Old 06-10-2013, 06:34 AM
sgtrgpfdps's Avatar
Mine is bone stock runs 200 with air on. I put in royal purple coolet add. wetter water brought it down.
Old 06-10-2013, 07:17 AM
AmDWs6's Avatar
TSP 1 7/8 .. 160 degree stat, never above 210 if not never near 210 and its HOT here. regardless, ac or no ac
Old 06-10-2013, 10:07 AM
Kmspeedie's Avatar
Im,in florida witha 02 ss..just.bolt ons..and I run about 200 alll the time
Old 06-10-2013, 10:16 AM
00MaroonZ28's Avatar
Should be around 200.
Old 06-10-2013, 10:33 AM
2002ss335's Avatar
1998 was the only year that the water gauge read temp. From 99 on the water temp gauge was redesigned to work basically as a dummy gauge and only show an overheat condition.
Todd
Old 06-10-2013, 01:19 PM
'99REDTA's Avatar
Perhaps my car is just a pile with mood swings
Old 06-11-2013, 04:19 PM
SPRAYED 01's Avatar
Amdws6, are you reading your temp from a scan gauge or tuning software?
Quick Reply: stock ls1 guys, what temp does your car run with ac on?
