Flexplate question 4L80E
So I'm starting my M6-A4 swap. My question is which flexplate do I need?
LS1 , 4L80E, 9.5" converter
I have no idea. A regular 4L80E flexplate won't work.
That appears to have the LS pilot and is multiple bolt pattern. So you could use the 4L80 setup with the spacer. Or you can use a 4L60 dished type. Do you actually have the converter yet, or is that just from the web? I need you to measure the pilot to pad distance.
Chris
Chris
Chris
Chris
Chris
Chris
So from that I should assume a flexplate for a 4L60E would work?
They sent me another email and said a flexplate for an 80E is what I need. All the ones I've seen so far for the 80E are for an 11" converter.
I know jack **** about automatics.
