9 second stock long block build thread!!! pics and vids inside!
alrighty, a few guys around here were asking about a build thread, so i felt like it deserves to be done.
background on the car:
1997 30th ann z28 6 speed. got it with 5200 original miles, 2nd owner.
this car has seen every setup out there, blower, nitrous, all motor, turbo, blower/nitrous, stoker/blower/nitrous, stroker/turbo/nitrous, now stock motor and turbo.
car IS and always will be a street car, full interior, full stereo, all working interior. no a/c no heat (bitch now or forever hold your peace)
i started this build with the intention of just being a high 10 second 6 speed street car, drive it to the track strap the slicks on go high tens a few runs and drive home.
i have a stroker motor with all the goodies ready for it but at the time i had no money to finish that motor and the season was fast approaching. so i decided ill go get me a stock motor and build a wicked turbo system around it and see how far i can push it (500 to 600hp was in my head)
Engine:
stock short block
stock bearings (new)
high volume std pressure oil pump
stock oil pan
stock lt1 heads with dual comp springs
ebay self aligning 1.6 rockers
ebay one piece P rods
felpro blue head gaskets
ARP head bolts
pro comp EFI single plane
wislon elbow
ebay 102mm TB
ls7 lifters
220 230 114 .544 .544 comp cam
Trans:
Coan pro400
PRN123N
full manual
pro brake
2 step
40 row cooler
Rear:
9"
nodular truck center
3.25 gears
31 spline moser axles
full moser spool
3.5" carbon driveshaft
front suspension is stock besides BMR K member
Rear suspension:
BMR race lowers
BMR lower relos
BMR pan hard
BMR relo torque arm
stock shocks
stock springs
turbo system:
custom manifolds 1.625" primary
3" cross over
cx racing GT4508 1.15 t4 divided
4" down pipe
cx racing 60mm gate
god speed dual 50mm BOV's
3.5 inch ic piping
pegusas clamps
cx racing water/air
halman manual boost controller
EFI/fuel system:
STOCK OBDI
open loop
speed density
150# injectors
pro comp rails
aero reg
-10 feed
-6 return
dual wally 450's in tank
first motor lasted 80 dyno pulls and 3 passes in the mid 10's, #6 rod decided it had enough, packed its bags and headed south out my 300$ oil pan. so got another motor which is the one i went 100% threw and she is holding well at 15 passes not one pass slower than a 10.44.
here are the pics of how it all started:
Engine:
stock short block
stock oil pan
ARP head bolts
wislon elbow
ebay 102mm TB
ls7 lifters
Trans:
Coan pro400
PRN123N
full manual
pro brake
2 step
40 row cooler
Rear:
9"
3.25 gears
full moser spool
Rear suspension:
BMR race lowers
BMR lower relos
BMR pan hard
BMR relo torque arm
stock shocks
stock springs
turbo system:
3" cross over
4" down pipe
cx racing 60mm gate
3.5 inch ic piping
pegusas clamps
cx racing water/air
EFI/fuel system:
STOCK OBDI
open loop
speed density
150# injectors
pro comp rails
aero reg
-10 feed
-6 return
Interesting placement with the nose piece fab work, looks good though. Get in a front end accident driving on the street and it will be toast though.
What's the smaller pipe coming out next to the exhaust pipe for?
I was hoping the inter poker was big enough to soak up a crash hahaha. I'm pretty good about driving it, I stay 3 to 5 cars behind people in town I'm constantly looking when crossing intersections. So far so good, usually ill blast the tires off down the highways or street and people seem to back off. Had some kid in a civic tail gate me for about a mile then I gave her the beans and needless to say I never saw him again. Car drives like stock, and it's really quiet cruising so I love to take it out on nice days. C16 fuel is a tad over priced so I try to limit my street driving, once I switch to e85 ill be driving it much more.
Looks like you detonated the stock bottom end. Im assuming you replaced the bottom end with stock components on this build.. I remember seeing a thread with the same turbo setup but with forged internals?!
correct i have a stroker getting ready for this but like i said money was tight and the season was fast approaching. wanted to get out there asap!
yes the motor that is in it now is still stock internals, but it was completely torn down and reassembled, rings gapped, bearings replaced with extra clearances, new oil pump.
piston to wall was around .0021 IIRC have to look at the sheet.
all stock parts were reused besides bearings and oil pump.
