need help asap tt lt1 breaking up in boost
Old 06-16-2013, 02:09 PM
tt383lt1's Avatar
Default need help asap tt lt1 breaking up in boost
so i got the car running and fnally got insurance on t so i took it out and it willnt let me get into boost maybe 3 psi until it breaks up. if i dump on it right away it will break up right away and get no to barley any boost. if i pedal it in first gear i can get boost on the top end. but as soon as i put it in 2nd gear it breaks up. it breaks up on the trans break at about 2.5 to 3 k last year i went to 6000 min and had 20+ psi, but it will let me get boost in park with no load maybe 3 psi enough to open the bov. i redid my cold pipes, intercoolers, new converter, i got fuel pressure, the map sensor is on the intake so i wouldnt think the cod pipes and intercoolers would effect that. its a sd tune. the plugs are cheap coopers plugs that have about 2000 miles on them when i redid the powder coat i didnt go internal on the engine just the covers ect came off. i didnt even pull the spark plugs out. so im stumped i went through every wire to make sure there right. after arket harness. the car idles perfect until u try to get into boost with a load.
but here is what i changed
moved mt driver knock sensor back about 3 inches to clear the engine mount better
intercoolers
shorter cold pipes
new converter
i left some e85 in the tank but i ran 15 galons threw it already and put another 12 galons in it yesterday have 44 psi at idle and dont see the pressure drop. so the filter souldnt be clog
im thinking plugs and wash the fuel filters out. ( i have metal mesh washable) but i wouldnt think those wouldnt get me into boost knowing how this thing purrs at idle. do i need a retune?
Old 06-16-2013, 02:22 PM
handyandy496's Avatar
sounds to me like spark blow out.....a not so hot coil or two. shorten the plug gap and see what happens. what's your gas to e-85 mix?
Old 06-16-2013, 02:27 PM
tt383lt1's Avatar
pure e85 mix i have local buddy running the same ethanol and have no issues at 28 psi and 950 rwhp at 28 psi. and i ran the same plugs last year and have no issues. if i crake a plug i think it would idle like ****.. but 20 bucks in plugs ant ****.
Old 06-16-2013, 02:29 PM
Cam72aro's Avatar
Car have the opti junk on it?
Old 06-16-2013, 02:35 PM
whats your plug gap?
Old 06-16-2013, 02:37 PM
check amps volts coils
Old 06-16-2013, 02:38 PM
tt383lt1's Avatar
no 24x conversion drove perfect last year. with the same plugs act and i can remember my gap. ill go pull one out and check
keep them coming guys this is bothering me i can figure it out. could i have crake a plug when pulling or installing the engine? and have it run fin at idle?
Old 06-16-2013, 03:23 PM
Cam72aro's Avatar
I would start with new plugs
Old 06-16-2013, 03:45 PM
tt383lt1's Avatar
what would you gap them too. i pulled them out and there from .27 to .35 which is weird if i remember right there were .27 but what would you guys gap them too. im going to try .27 until i hear diffrent on here. thanks everyone
Old 06-16-2013, 04:26 PM
tt383lt1's Avatar
all new plugs did nothing. anything else?
Cam72aro's Avatar
I usually run .025 everyone has their own opinion and preference.
Old 06-16-2013, 09:28 PM
tt383lt1's Avatar
no one else? im getting a scanner tomorrow and ill figure whats happening i hope
Old 06-16-2013, 09:30 PM
vwdave's Avatar
I would run .025-.026 and go from there. Did the plugs look beat to hell?
Old 06-16-2013, 10:03 PM
Cam72aro's Avatar
Does the car have meth on it?
Old 06-16-2013, 10:06 PM
tt383lt1's Avatar
no they look really good and no meth wta intercoolers
Old 06-16-2013, 10:40 PM
Cam72aro's Avatar
What plug wires?
Old 06-16-2013, 10:43 PM
vwdave's Avatar
Im kinda starting to wonder if its a voltage issue involving the ignition system.
Old 06-16-2013, 11:04 PM
tt383lt1's Avatar
What plug wires?
msd 8.5mm custom wires.
Old 06-16-2013, 11:19 PM
tt383lt1's Avatar
and are all gm map sensors the same is a 1 bar a 1 bar and 2 bar a 2 bar? i have a couple of maps around the house and i know what bar they are as long as i switch it with the same bar will the ecu recognize it as the same or does each map has its own values?
Old 06-16-2013, 11:27 PM
1INSANEGTO's Avatar
I'm having the same issue with mine. I have NGK TR7IX plugs @ .23 but mine starts to break up on high boost. I can get run low boost with no issues.
Quick Reply: need help asap tt lt1 breaking up in boost
