C5 and C6 Corvette owners Check this out!
Hi Everyone!
C5/C6 Corvette owners know that the front skid plates are vulnerable to getting bumped and scraped. Fangs from SacCityCorvette provide the best possible protection available for your front skid Plates/Lower Radiator support on your C5/C6 Corvette. Made of a High Impact Superior Performance Plastic, the C5/C6 Fangs are extremely impact resistant and 6 times more abrasion resistant than steel and Installation only takes a few minutes. Being only 1/8" thick you will not even notice any clearance loss. There is NO drilling or modification required! C5 Fangs are a simple 10 minute bolt on using your factory bolts. C6, you simply glue them on or if you prefer, they can be screwed if you order the screw on kit. It comes with drill bit and tapping screws. Once the Fangs are installed you will have the best protection available. $49.99 is a very small price to pay for such good protection of such an expensive part of your Vette!
2)The superior performance plastic we use is 6 times more abrasion resistant than steel making them slide very smoothly over what ever they come into contact with.
3)They perform perfectly in hot or cold weather.
4) They distribute the load over the entire skid plate where it is the strongest and can evenly distributes the impact, not on one side or the other where the side load can bend skid plate.
5)There are no moving parts to wear out.
6)They only weigh 5oz for those that worry about weight.
7)There is no drilling or modification needed to install them
8)The Fangs give protection over the entire skid plate. So if you bump up on a parking block like we demonstrate in our video you are protected from the front to back and from the highest point of the skid plate to the lowest.
9)They look like something that came on your Vette from the factory.
Here is info for the C5 Fangs
http://www.saccitycorvette.com/Fangs.html
Here is a video of the Fangs getting used!
Some of the Benefits
1) They are only 1/8” thick so there is no noticeable ground clearance loss. That’s very important since there is not much clearance there to begin with!2)The superior performance plastic we use is 6 times more abrasion resistant than steel making them slide very smoothly over what ever they come into contact with.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Sorry, didn't realize I had 2 posts under the same subject.
I deleted one of them.
__________________
Hi danieloneil01,
Without all the great sponsors on LS1Tech and other forums paying $ to run ads to promote there products there wouldn't be a forum like this so you can be on here for free.
Christian
__________________
Hi, overbearing sponsor.
I go on plenty of sites that don't have sponsors who flood every section with their products. Some of these sites actually have sections strictly for sponsor advertising.
City-data is one of them and they do just fine without sponsors. Another one is AVS forum which doesn't have sponsors who have to post advertisements. But again you seem to think sponsors are the only ones who keep forums alive. Thanks for your contributions.
AVS and city data
I didn't pm you or tell you to click on my post or push our products on you!
You came here and start ****. I think you just have to much time on your hands and nothing better to do. And I wouldn't exactly say we are flooding the forum with ads! Have a nice day creep!
__________________
Search Corvette Forum if you want to know how well the Fangs work.You'll be surprised!
__________________
Now available for the C7 Stingray!
__________________
Benefit is that with the Fangs, you only loose 1/8" of ground clearance, the bar is fully protected front to rear, the load is distributed more evenly, lighter weight(6oz), they make the bar look nice and there is no drilling involved.
Thank you,
Christian
__________________
Thank you everyone that purchased products from SacCityCorvette! Your business is greatly appreciated!
__________________
We have C5, C6 and C7 Fangs in stock. Installing a pair of Fangs will help protect your expensive lower radiator support during your summer driving!
C5
C6
http://www.saccitycorvette.com/C6-Fangs.html
C7
http://www.saccitycorvette.com/C7Fangs.html
C5
C6
C7
__________________
Have you looked at your skid plates lately?
__________________
If your doing the rear main seal, its a good time to toss the loose factory oil diverter/barbell and install one of our Precision fit billet barbells and start keeping unfiltered oil out of the bearings.
http://www.saccitycorvette.com/Billet-BarBell.html
only $26.99
Thank you,
Christian
only $26.99
Thank you,
Christian
__________________
Hi 96darkhorse,
We have them in stock when you are ready.
Thank you,
Christian
Thank you,
Christian
__________________
