Max compression ratio
It shouldn't matter whether or not you're running carb or FI as to the max compression you can run. Max compression you can run on a particular fuel is determined more by the shape of the combustion chamber and cam timing.
Cam timing does have a huge effect on the static compression you can get away with, but when the engine finally gets to max torque (max efficiency ) the spark knock will come in with say, a fat duration cam. Dynamic compression is what has the major effect on whether or not you can run on a certain fuel or not, or how much lead you can run in the timing on a particular fuel octane .
Old School Heavy
Another consideration with higher compression on a carbed motor is "engine run on". I have 10.9:1 and if I run 87 octane it will run on a bit on a hot day after the key is turned of. Unlike fuel injection, a carburetor will keep delivering fuel even after the ignition is turned off. So, if you get the compression too high, you may experience run on where you would not with fuel injection.
I think i'm going to go max of 10.5, sorta like i used to on old sbc with alum heads. I know EFI is easy to tune for higher CR, i was trying to see what alot of you guys were running.
