Max compression ratio
Cam timing does have a huge effect on the static compression you can get away with, but when the engine finally gets to max torque (max efficiency ) the spark knock will come in with say, a fat duration cam. Dynamic compression is what has the major effect on whether or not you can run on a certain fuel or not, or how much lead you can run in the timing on a particular fuel octane .
