Identify connectors E38 Truck Harness
Could someone tell me what the two connectors are, that branch off the main trunk, lower center of the picture. The bottom one has a connector similar to the ECM connectors but has no cover and connects to that plate or module.The one above it is gray and blue and the underside is tan oval pin connector.I think I know what they are but I just want to verify.
Yes you can delete that since it will be a 5spd.
That connector above it would be what plugs into the Body Harness going to the Interior..this has the Pedal Wires and the Serial Data high and low wires in it. I have one of them Harnesses in my hands right now looking at it.
FWIW, on my E38 truck harness, the serial data lines were not continuous from the ECM to the x109 connector, but they jumpered inside of the TCM. So if you're planning on running the x109 wires thru the firewall, you'll need to splice them at the TCM if you delete that branch..
