Few Plug ID Questions On 99 Harness
I'm Working on a wiring harness right now , and there is a few plugs I'm Either not finding the Schematic on ALL data , or Mitchell. I'm beating my head against the wall trying to figure these plugs out. Harness is 99 Camaro Manual Trans.
I'm Going to Post the pictures of the connector , and where about it is located.
First plug is located about a foot past the connectors going into the column.
It's in the Harness coming into the car from the under hood electrical connector.
The second plug looks to go somewhere around the passenger side as its just a touch longer than the two interior connectors the ling to the harness.
So what year are you saying it is. Judging by everything else I have cleaned up it lined up with 99. I was actually thinking that but that part of the harness goes from under the hood into the car. The Tac Module is generally under the hood tho. Let me check a schematic for tac module.
What your not understanding is the car has 3 harness's. The motor harness, The Interior Harness , and the Underhood fuseblock harness . The underhood is what the tac looking connector is. Let me take another picture here so you can understand .
As you can see the "pass thru" Then the rest is inside the car. There isn't another plug under the hood for a tac module.
I was told By the customer it was a 99 Camaro. I got it out of the car and fuse block was bolted in when I picked up the harness. While I enjoy wiring its always fun pickup up somebody's basket case. But I guess that why they pay for it.
Show us the connectors at the throttle body and we'll be able to tell you more.
I was kind of starting to think that dbw myself. But never thought to check v6 harness. I pulled it all out anyways so I'm good. Strange that it was v6 , and stick tho.
