d1sc pulley bolt making contact with alt pulley
Old 09-06-2013, 06:31 PM
dc4bill's Avatar
Default d1sc pulley bolt making contact with alt pulley
I Did A Quick Search And Saw Some Others Have Had This Problem, Only Saw One "Possible" Fix. Im Running The Truck Alt And Was Wondering If Anybody Had An Actual fix
Old 09-06-2013, 07:03 PM
Fall Line's Avatar
I couldnt make the truck alt fit. It looked like a smaller 12pt bolt head would provide clearance but I couldnt find one locally so I just put on a 105amp delco.
Old 09-06-2013, 07:12 PM
dc4bill's Avatar
Well dammit lol gues that's what I gotta do
Old 09-06-2013, 09:25 PM
conan's Avatar
Have you verified the pulleys are straight and lined up. The stand off nuts could be too short ?
Old 09-06-2013, 09:46 PM
dc4bill's Avatar
According to the install instructions the stand offs are the correct length for the 8rib setup
Old 09-06-2013, 11:21 PM
conan's Avatar
I would check the alignment with a straight edge or a laser tool before buying a new alternator and guessing the pulleys are ok. I had to shim my pulley because they were off slightly and the belt would want to move off the crank pulley.
Old 09-07-2013, 07:41 AM
steelgraygtp's Avatar
I had the truck alternator too. Tried the smaller bolt but it still hit. Wound up getting a stock alternator.
Old 09-09-2013, 12:06 PM
dc4bill's Avatar
swapped alts and it looks greast, drove it to the shop without issues
Old 09-09-2013, 05:32 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Yeah, the truck alternator won't work with a procharger setup, at least not as designed by the factory. You could always fab a new bracket or do some fabrication and get it to work I guess.
Quick Reply: d1sc pulley bolt making contact with alt pulley
