C5 t56 assembly: need help.
Old 09-28-2013, 04:57 PM
nobird8991's Avatar
Default C5 t56 assembly: need help.
so I took apart my first c5 t56 (triple/ double friction synchros,) which was actually an SSR main shaft fit for a F-body t56, and it was toast. had to get new main shaft and a lot of hard parts.
trying to reassemble and stuck on the 1/2 synchro install. I got a lock ring kit since the old one were beyond recorecognition and I'm not sure where they all go. it looks like a lock ring should go on top the synchro between the synchro and 1st gear but the opening is twice as thick so maybe not. since this is where all the carnage was I want to make sure it's right.
if someone could help that'd be great.
Jeremy
Old 09-28-2013, 05:00 PM
nobird8991's Avatar
here is a picture of where I'm at with it.
Old 09-28-2013, 08:45 PM
sabastian458's Avatar
Yes there is a snap/lock ring that goes there. It's thicker than the "normal" snap rings.
Old 09-28-2013, 10:08 PM
jmd
jmd's Avatar
the 1-2 synchro retainer parts are documented in the PDF downloadable in this thread:
https://ls1tech.com/forums/manual-tr...ock-parts.html
Old 09-29-2013, 12:44 AM
nobird8991's Avatar
jmd, what post is it in?
Old 09-29-2013, 07:42 AM
85MikeTPI's Avatar
https://ls1tech.com/forums/13121283-post24.html
Old 09-30-2013, 12:14 PM
nobird8991's Avatar
okay thanks.
one last question, if I have a 2.66 ratio trans(39 tooth first gear) is their any stock gear that has the machined lip oem or do I have to get it machined?
Old 09-30-2013, 02:13 PM
jmd
jmd's Avatar
Originally Posted by nobird8991
okay thanks.
Yes, there is. The PN is in the PDF. Keyword: MM6
Old 09-30-2013, 03:39 PM
nobird8991's Avatar
thanks a bunch. i should of read the whole damn thing lol, it won't open on my computer so i'm reading it on my phone ftl.
Old 10-08-2013, 08:43 PM
nobird8991's Avatar
so I found everything but the little ball bearing that holds the washer retainer in place, any idea what the dimensions of the ball is or where I can get it?
thanks, Jeremy.
Old 10-08-2013, 09:15 PM
85MikeTPI's Avatar
thanks, Jeremy.
Also in the PDF file
4.75mm stainless ball bearing
I have a few hundred of them if you'd like to PM me you're address I'll drop one in the mail.
FWIW, the TR6060 has the same designed retainer, but doesn't use the ball bearing. The CTSv T56 used the ball, so I used it in my build... YMMV..
Old 10-09-2013, 12:10 AM
jmd
jmd's Avatar
If you're in a hurry, 3/16" is fine and easy to find.
Quick Reply: C5 t56 assembly: need help.
