Trying to pull the Transmission out!
I'm trying to install a slave cylinder and for the life of me I cannot get the tranny to come apart at the top.I know about the 8 bolts and the electrical hook ups. I have everything I know of un hooked or off. It's like something on the very top is still attached? I have watched 2 video's over and over, and 1 video talks about having something being attached at the top causing a little problem.
As dumb as this may sound, yes and I used long extensions also, but I only have 7 bolts on the ground. One was misplaced, but I can see and count the 8 holes.For a long time I kept looking for another top bolt thinking one had to still be in. I can move the tranny pretty good to see a dowel. But as soon as I let go, it pops right back together. The top doesn't come apart like the bottom half, that's why I felt there was a bolt, but I can't find it.
There are two studs that connect the tranny and bellhousing and if they haven't been separated in a while they can be a PITA to separate. I was jerking the entire motor/tranny from underneath trying to get them to separate. I ended up using a small prybar in the slots on the side to get them apart. I was exhausted from trying to pull the tranny off. The prying would have saved me a lot of effort if I had done that in the beginning.
Be careful with the input shaft as your pulling the trans out....because of space limitations its easy to scratch it on the pressure plate fingers. you will understand if you have to replace it...
mine was also stubborn...be patient and work it GENTLY. if you get rough with it, get ready to open your wallet...speaking from experience.
Been busy at work so only thing I have done is went to Harbor freight and bought a trannsmission jack and realized that I only had 7 bolts out!! Hoping to get the last top one out tomorrow after work or Saturday.
Your video was great,but you made it look way too easy! My luck isn't that easy! I'm outside under a carport, and it's raining.I ran a long ext from the back of the tranny and it went right to the bolt! Tranny is down and out! Now it's time to take a break and figure out if my clutch is worn or is it time for a new one.I'll put the slave on tomorrow.
Yea I saw your video 4-5 times,and I'm 6'5" 325 lbs and I went out and spent $84 on my tranny jack! I was not going to take a chance on dropping it, plus I had 2 jacks and it just didn't feel right. The tranny jack made it soooo easy.So since I had to pull my Y off at the cats, cause the tranny just wouldn't pass by it, I'm just going to shine up my stainless Y pipe and headers tomorrow. I'll have to get my buddy to come by next week and tell me about my clutch.
