Would you or would you not?
I dont run anything less than 10.0:1 but I run meth. That suoer low compression stuff is old school, more power you maie NA the more power youll make per pound and the easier it is to bring the turbo in. As long as timing is not cazy. I would look into the TU0 though but then again you d8dnt list what turbo your running.
Dude, do a search. The internet is your friend.
http://en.wikipedia.org/wiki/GM_Vortec_engine
Every spec you can imagine is out there... just ask a search engine...
http://letmegooglethat.com/?q=5.3+heads+spec
See?
So when I input specs I get more CR than stock
3.78 bore
3.622 stroke
4.100 bore head gasket
.051 head gasket thickness
59cc heads
-6.0 dome
.008 deck height
give me like 10.6
But If I dont use a negative input like it says then im at 9.36
3.78 bore
3.622 stroke
59cc heads
-6.0 dome
.008 deck height
give me like 10.6
I wouldn't hesitate to throw 20lbs at that. 9.3:1 is good for a pump gas and meth setup
Using your numbers, with a 0 deck height I get 9.76:1. You say your piston is sticking out 0.08 above the deck, did you measure that? I ask because then your compression jumps to 11.86:1. If I go the other way and you piston is 0.08 in the hole I get 8.34:1
Check over your specs to be sure that's what you have for your measurements.
