Would you or would you not?
With a 9.5 CR
so down 2 points should make about 9.8 cR correct?
Hell many tuners want 10:1 or 10:4 CR for big boost especially if using e85 or 110 octane
Run it and let us know what happens. Plenty of people have done it before...
Dude, do a search. The internet is your friend.
http://en.wikipedia.org/wiki/GM_Vortec_engine
Every spec you can imagine is out there... just ask a search engine...
http://letmegooglethat.com/?q=5.3+heads+spec
See?
3.78 bore
3.622 stroke
4.100 bore head gasket
.051 head gasket thickness
59cc heads
-6.0 dome
.008 deck height
give me like 10.6
But If I dont use a negative input like it says then im at 9.36
You have to read the fine print
That CC is kind of low but not much lower than stock being 61.15 and people are pushing well over 20 lbs on those stock 706 heads.
Just get a solid tune, high octane gas or e85
Using your numbers, with a 0 deck height I get 9.76:1. You say your piston is sticking out 0.08 above the deck, did you measure that? I ask because then your compression jumps to 11.86:1. If I go the other way and you piston is 0.08 in the hole I get 8.34:1
Check over your specs to be sure that's what you have for your measurements.
Didn't pay attention to that 1 little zero
