Cracked FAST intake and replacement option
My car is a 02 Formula with some bolt on. Anyone ever experience this? I've a crack running all the way across the bottom of my FAST 90 intake. Plus there's 2 injector port cracked. Also, the whole bottom is kinda shifted, looks like due to heat.
Looking for replacement now. Either going back to stock LS6, or Holley 300-111, or BBK SSI with the 80mm TB. I'm more into Molley because of price point ($400) and being aluminum. Going for a FAST 92 is more than double price and I'm afraid same thing might happen again.
I did change the bolt. Also, the injector port crack out of the molding don't make sense.
Anyway, I haven't update my parts knowledge for long time. I don't even mod my car much now. Will you guys recommend the BBK SSI or Molley?
Contact comp cams and see how they can help. Looks to me to be regular head valley bolts not switched to button head and/or possbily overheated??? I wouldn't think button head bolts wouldn't cause those impressions unless the heads were seriously milled and I still wouldn't think that could happen.
I'm hoping they sell the piece separately. Mine is the older FAST 90 not 92. Not sure if those still available.
BTW, no one have opinion on those BBS and Holley intake?
