Huron Speed Custom Single T6 Kit *Martins*
Up for sale is a Custom one-off T6 Turbo Kit. This kit was built for Martin's Real Street car, but plans have changed slightly in terms of the turbo kit, so we are offering this one up and helping him with another!
-Kit utilizes Truck Manifolds
-2.25" crossover pipe, true divided into a divided T6 flange
-Includes bungs for primary O2 sensors in the crossover
-Turbosmart 60mm gate flange pulling from both banks of the crossover
-Custom 5" to split 4" downpipes
-Downpipe features a custom tight radius 5" to clear inside the factory frame rail. V-banded before it exits the bumper for easy tip exit install. Bung for wideband installed as well
-Kit has never been ran, simply mocked up
-Was set-up to run Non-Intercooled with a direct straight shot into the TB from the compressor housing.
-Compressor housing is for a S476R BW turbo modified with short cold side pipe with Turbosmart 50mm BOV flange, IAT sensor bung, and drilled for a meth nozzle pre-IAT
-FAST 92mm Big Mouth TB modified with v-band style clamp set-up to bolt to the compressor housing.
-Alternator relocation brackets included
-Kit requires waterpump with shorter snout. Factory LS1 snout hits compressor housing
-Kit also requires a stood up radiator obviously as you can see where the turbo sits.
-Kit was built around factory power steering
-Kit is coated entirely in Ceramic Black
*Turbo not included
*Wastegate and BOV not included, however we can provide the buyer with NEW Turbosmart units if interested for a terrific price!
$1995 plus $95 shipping includes:
-Crossover pipe
-Custom 5" to split 4" Downpipe with v-bands and 2 exiting 4" tips
-All Ceramic Coated BLACK
+$975 to include the modified Compressor housing, modified FAST 92mm Big Mouth TB w/ IAC and TPS sensor for it.
*If purchasing without the comp housing and TB, you can run a standard BW T6 turbo and just make a simple stubby pipe for it like shown below with the White housing Turbo!
*Turbo not included
-Crossover pipe
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
__________________
The compressor housing is drilled for meth, and he was also going to spray meth into the compressor wheel. This with E85 I am sure would have ZERO issues with IAT temps
__________________
Yeah I know about the details. Even seen the kit in person. Nice piece for sure but Martin wants what he wants lol.
__________________
Nothing has been planned yet. Moving this kit first.
__________________
Yea, it came out pretty cool! We vbanded it right before they exit the bumper for an easy tip install and makes it easy to change the tips as well if you want a different look out of them!
__________________
Still here, PM for a smoking deal!
__________________
Still available!
__________________
