Super Budget square body swap
I am officially done with fourth gens. not sure why but i cant seem to not buy one and now that i sold my SS i can start fresh with a swap. i already considered buying a 99+ chevy with the motor in it but ive always been into C10s. now before the flames are thrown, i really wanted a 67-72. the only trucks in my budget were rusty long beds with alot of problems and personally if im gonna spend 5k+ i would rather get a newer truck. so looks like my only option was a 73-87. i wanted to stick with the 81-87 because they have the better interiors and nicer front ends. i decided to go super cheap because i was gonna be replacing alot of stuff anyway. looking back I should have bought one that was on the road and the swap would have been easier. Picked up a decent 87 stepside for dirt out of a guys front yard. Found a 2004+ 4.8 on CL for 150 complete with accessories. I used a trans from my 2000 trans am I parted out a while back as well as some other stuff (fans, intake, throttle body, PCM, and waterpump). My apts were being a PITA and towed it so I had to get it going quickly so I wasn't very neat or thorough the first time. Now that it is all legal I tore it all back down and did it right. I finished this swap for less than $3000 including the HPTuners, Vig stall and Autometer gauges. Pics coming asap
ok I am just picking up my 5.3 to do this in my 86 k10. can you tell me what parts u used. I still have to pick out motormounts and everything I have nothing but the motor picked out w acc harness and comp/exhaust I plan on using my duals just adapting for the manifolds on the ls if needed
did you remove all of your stock wiring harness? I intend to keep mine so I can keep my gauges
anyways any info will b great
nice work on a tight budget! I like the stepside look too! Get her up and lets see a burnout vid!
On a technical question, did you relocate the standard belt tensioner to the location between the PS and alt? I do not think I have ever seen a set up like that! Nice job fitting the old AC compressor in there!
Thanks for the info.
