Thinking of shortening new rear.
Old 10-31-2013, 06:25 PM
bottlefed01z28's Avatar
Default Thinking of shortening new rear.
Ok Ive already got the money together to order my new rear end. I Have already decided to get a MWC 9". The wheels i have on there now are Weld Pro stars. when i get the new Rear im thinking of changing to the Weld RT-S S71 wheels or the billet specialties street lite wheels. Im trying to go for a dish look on the wheels so im figuring i need to shorten the rear to reduce the back space i put on the new wheels. i was thinking of shorten the rear about 2" on each side. If i shorten it this much i want to make sure i dont have to cut the car at all. i dont want to do a mini tub or anything like that. Is this possible if so does anyone have any pictures.
by the way the wheels i have are 15" by 10" in the rear
Old 10-31-2013, 06:44 PM
alexus6798's Avatar
You can go up to 3" each side without modifications to the car, but your current wheels will not work as they will have the wrong offset.
Old 10-31-2013, 06:49 PM
thank you thats what i wanted to know.
i know the wheels i currently have will not work which is why i would get the new wheels if i shortened it.
does anybody have any pictures of this type of setup?
Old 10-31-2013, 07:08 PM
alexus6798's Avatar
Check out this thread>https://ls1tech.com/forums/gears-axl...cs-please.html.There are a bunch of more threads if you search this site...
Also this one>https://ls1tech.com/forums/wheels-ti...uote-pics.html
Old 10-31-2013, 07:13 PM
ugh i suck at searches thank you
Old 10-31-2013, 07:14 PM
alexus6798's Avatar
Oh yeah, I forgot, you will have to do the BFH mod and maybe roll your fenders, but you won't have to cut your car up...
Old 10-31-2013, 07:26 PM
well i did do the bfh mod on the front inner fender of the rear. im running the 15x10 wheels with a 7.5" bs and my wheels are 275/50/15 so i was thinking of going with a 15x10 but with a 5.5" bs and keep the same tires when i shorten it 2". My thought process is if i take 2" out of the rear i can take 2" off the bs which will give me the desired look.
Old 10-31-2013, 07:38 PM
alexus6798's Avatar
you are correct...
Old 11-01-2013, 08:33 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
Thanks for your wise selection of the MWC rearend! You will have great peace of mind knowing you have the best parts for your money!
We can easily go -3.5" each side with the Strange housing ends, and up to 5 off with LCA bracket mods. Figuring backspace on a 10" wheel uses 7.5 at stock width, subtract your narrowing number from that.
Our most popular narrow is -3.0 each side, which usually uses a 10" wheel with a 4.5 backspace.
There is no extra cost for narrowing the rearend, the wheels are more common, the rearend weighs less, and a shorter axle is stronger. There are a lot of benefits compared to the stock dimensions. The one thing you all need to keep in mind when selecting wheels you must consider the brakes at the same time. The late model f-body brakes are quite large(and heavy) and won't work with most 15" wheels. We do offer great brake packages from Strange and Wilwood.
Old 11-01-2013, 09:18 PM
ok that sounds great then ill do the 3" and get a 4.5" bs wheel. now if i can only make up my mind about getting a locker a spool or some type of posi unit.
Old 11-02-2013, 10:12 AM
alexus6798's Avatar
Don't get a spool unless you don't plan on driving the car on the street..Some people do it but I wouldn't..
Old 11-02-2013, 01:52 PM
My problem is price. I've already had to scrap the idea of an aluminum case so I can save money. And the spool is included. The locker is only $300 additional but the s-trac is an additional $800. I by no means drive this thing daily. It usually sits in my driveway for a month or two on end. I'm pretty sure though once I get the new rear I will drive more often. But more often to the 1/8th mile track (which is only 20 mins away) or the 1/4 mile (which is an hour away). Every once in a blue moon do I get asked to show up for a show.
Old 11-02-2013, 02:17 PM
alexus6798's Avatar
You have to just be very realistic with how you plan on using the car. You don't want to invest a lot of money and be unhappy with your purchase.
Old 11-02-2013, 03:36 PM
I know
Old 08-31-2021, 07:08 AM
biketopia's Avatar
https://ls1tech.com/forums/market/1952295
Quick Reply: Thinking of shortening new rear.
