Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Fastest blow-through turbo/supercharged, using MSD 6010/6012?
Old 11-22-2013, 02:59 PM
3pedals's Avatar
Default Fastest blow-through turbo/supercharged, using MSD 6010/6012?
How fast have you been using a 6010/6012, and at what CI, and race weight?
I'm looking for the limits of the ignition system. Have you experienced any high boost misfire ?
Mines not close to maxing it, but I'll start:
9.57@147 - 6.0L, 3510 race weight
Plugs- NGK R5671-A8 Stock # 4554 gapped .015"
Old 11-22-2013, 05:24 PM
windmill's Avatar
What plugs you using, and also what the gap on them too,,,,, that info would help people out,,, id love to turbo my mustang..
Old 11-22-2013, 05:31 PM
3pedals's Avatar
Plug info added.
Good call
Old 11-25-2013, 07:51 AM
Prorac1's Avatar
Also, what boost are you running. When others add their boosted info, it would be a good comparison for hi boost mis fire. Just my .02. Good idea Barrett. Eric L
Old 11-29-2013, 02:16 PM
knuts82's Avatar
Never got to the strip but
msd 6010
csu 750 e85 blow thru
twin 6162 turbos on 313ci
8000rpm 23lbs of boost
23°total timing
Autolite 103 plugs .018gap
no spark blowout or misfire
In the process of building a 86 Notchback ls motor 6010 with another csu carb shooting for low 5's in the 1/8th.
Old 11-29-2013, 02:58 PM
In-Zane Moderator
ZONES89RS's Avatar
Low 5s....sounds fun. Lol. That's my goal for my mustang in the long run. Low 5 second street car.
Old 11-29-2013, 03:47 PM
396375's Avatar
So you think the ignition system would have any more limits then stock EFI ?
Old 11-29-2013, 04:54 PM
3pedals's Avatar
No idea, but I was reading another thread which sugested that it would start to fail at a certain point.
I'd like to know what guys are seeing
Old 11-30-2013, 12:47 PM
396375's Avatar
As long as both systems had equal tunes,I don't see any difference.You still have the same coils firing the plugs.
Old 11-30-2013, 06:44 PM
3pedals's Avatar
So how fast is yours?
Old 12-01-2013, 03:53 PM
396375's Avatar
I'm still building.3 years ago my twin turbo C5 ran 9.92 @ 145.
Old 12-03-2013, 05:20 AM
Pop N Wood's Avatar
Useful thread, but I would think the coil packs are what limits the ignition in high HP applications. All the box needs to do is provide a 5V trigger to the coils.
Old 12-03-2013, 08:44 PM
JRracing's Avatar
Yes, you are correct. The coils provide the voltage and they have plenty lol.
Old 12-03-2013, 08:47 PM
JRracing's Avatar
I have some parts lying around and thinking about building a turbo 347 ci or a 383 ci with what I have.
I'm not sure if I want to go blow thru carb or fi. Seems how I'm already setup for carb it would be much cheaper to go that rout.
I need it to make 950hp or more. I want to go 8.0's around 170mph.
Quick Reply: Fastest blow-through turbo/supercharged, using MSD 6010/6012?
