Switching from c 16 to q 16
Old 11-29-2013, 11:22 PM
chevyrunner's Avatar
Default Switching from c 16 to q 16
long story short, ive been running c-16 through #42 green top injectors for quite some time, made great power,( but im on a motor tune, i dont have a turbo or super charger). c-16 is for turbo-supercharger or big nitrous
im going to be running a 150 shot of nitrous which means some timing will be taken out so im thinking of going to q 16 as it makes more power at lower timing as well as burning faster and having oxygen in the fuel...
i have a stroker motor, nice compression, i cant say much more than that because my competition looks at my posts on here.
its as simple as draining my tank adding q-16 and getting a re tune right? my current #42 green tops are no where near full duty cycle now, so shouldnt be an issue...
any input appreciated
Old 11-30-2013, 07:59 AM
LS1TECH Sponsor
Lonnies Performance's Avatar
You will probably need approx. 10% additional fuel as long as your fuel system has the added capacity.
Remember this stuff can be tuff on the fuel system. Not sure I would leave it in the car long term.
Old 11-30-2013, 06:24 PM
BIGsmokey10's Avatar
yup the MTBE is harsh on fuel parts.. look on the bullet, most everyone running it after a race is draining the tank and flushing it.. smells like **** to lol.
Na you will pick up power and as you said you need more fuel because of the oxygenation.
Nitrous You can use it, but will make the tuneup more difficult and finicky.
Old 11-30-2013, 07:59 PM
im running 42# svt green tops that if i believe were at 80% duty cycle, i still have some room to bump up for the q 16 right?
is the q 16 really that much more harsh then the c 16?
Old 12-01-2013, 07:35 AM
Old Geezer's Avatar
The injs I've cleaned, that are used w/ Q, are not usually "nice".
@80% now, you don't have a lot of head room.
Old 12-01-2013, 06:54 PM
can you clarify a bit more? vp told me i would need to add 4 percent more fuel? shouldnt i have enough?
Old 12-01-2013, 07:28 PM
Gray86hatch's Avatar
Care needs to be taken when using q. It needs to be fresh out of a unopened can. Sitting in the tank for more than a day or so and it will be junk. I would find something different for fuel.
Tim
Old 12-01-2013, 07:42 PM
Tim
thats not a problem i only race the car and have a seperate fuel tank
Old 12-03-2013, 07:12 PM
Blackpanther99's Avatar
You should be good. Give it a shot.
Old 12-13-2013, 10:55 PM
soundengineer's Avatar
dont do it unless you upgrade to a bigger injector....
you are already at 80%... its just pushing it too far to be useful
you will need closer to 8-10% more fuel, and your tune up wont be as forgiving as c16
you will need to clean the injectors OFTEN with q16...and you will need to flush out your system after every race day
once the stuff is in your tank over night, it needs to be thrown away...its no good past about 12-18 hours....
and expect it to gum up everything...
seriously, be ready to clean out your fuel system OFTEN with q16
oh, and dont get it on your skin... that **** causes cancer..LOL
Old 12-15-2013, 08:58 AM
called vp they said only a 4% increase may be needed also dont forget that while i am using 42 pound injectors they are ford injectors they flow higher at ls pressure
Old 12-20-2013, 10:59 PM
chrs1313's Avatar
Might want to just try the fuse unleaded 116...if you want the oxygenated effect just up one more jet size...
Quick Reply: Switching from c 16 to q 16
