104rwhp/59rwtq gain Tick Performance custom blower camshaft
Old 12-04-2013, 02:15 PM
Sales@Tick's Avatar
Default 104rwhp/59rwtq gain Tick Performance custom blower camshaft
Did a cam install on a customers 5th gen the other day. Finally got around to putting it on the dyno to dial it in.
The only thing that changed were the valve springs, push rods, timing chain, gaskets and camshaft.
-Stock bottom end LS3
-Stock LS3 heads
-Stock LS3 intake
-Stock LS3 TB
-Procharger D1SC w/ 4.38" blower pulley and stock balancer
-11psi@6800rpm
-Custom Tick Performance Centrifugal Blower Camshaft 223/239 .617"/.621" 115lsa
-Brian Tooley Racing .660" lift Platinum springs
-Comp Cams 5/16" .105" wall push rods
-Kooks 1x7/8" Long Tube headers
-Kooks 3" catted X-pipe with 2.5" OEM connections
-Stock 2.5" Cat-back exhaust
-TR-6060 trans
-Snow Methanol Injection (unknown gph)
-93 octane
SAE Corrected before and after:
Uncorrected before and after:
Pretty happy with the results!
Old 12-04-2013, 02:18 PM
HCI2000SS's Avatar
So no change in the amount of boost either?
Old 12-04-2013, 02:23 PM
a98ws6's Avatar
Nice! No vid?
Old 12-04-2013, 02:48 PM
Sales@Tick's Avatar
The pulley's were left unchanged. Nothing changed but the camshaft and supporting valve train modifications.
I'd have to ask Jonathan to look at the logs to compare. With added VE manifold pressure will register a lower value in the intake.
Originally Posted by a98ws6
Nice! No vid?
Idle or dyno?
Old 12-04-2013, 03:12 PM
mrstepheneades's Avatar
Cam really woke it up.
Old 12-04-2013, 03:14 PM
Sales@Tick's Avatar
Baby cam.
Old 12-04-2013, 03:17 PM
Old School Heavy
speedtigger's Avatar
Damn, those little D blowers can make some great power. What is the ceiling on one of these units?
I need a gauge for that
Atomic's Avatar
Was the before with a stock camshaft?
Old 12-04-2013, 03:19 PM
Sales@Tick's Avatar
I would say 800rwhp on a street car with low compression and pump gas.
There is a car that runs our local RS275 class with a D1SC and a 300 c.i. SBF 8.2 deck motor with a A2W.
That car has been 5.20@133-134@3300lbs.
Sales@Tick's Avatar
Yes. LS3 camshaft.
Old 12-04-2013, 04:00 PM
Old School Heavy
Wow. I had no idea that D blower to make it happen like that. Tough unit.
Old 12-04-2013, 04:19 PM
Sales@Tick's Avatar
Ok, spoke with Jonathan about the boost at different RPM's.
This car does not have a 2 bar map sensor. This is a 5th gen with virtual VE(I believe it is called in the aftermarket realm of calibrations) and we only verified boost with a mechanical gauge.
On the stock camshaft at 6300rpm it made 10psi. New cam at 6800rpm makes 11psi.
No hard data to go off of but that.
Old 12-04-2013, 04:25 PM
HCI2000SS's Avatar
Considering that info it's still very impressive I must say
Old 12-04-2013, 04:55 PM
Brian Tooley Racing's Avatar
Nice work Martin!
Old 12-04-2013, 05:16 PM
Sales@Tick's Avatar
Originally Posted by Brian Tooley
Nice work Martin!
Thanks Brian!
Old 12-04-2013, 05:37 PM
jjcamaro02's Avatar
Great job Martin!
I hope i pick up power like this with my custom cam.
Old 12-04-2013, 05:44 PM
Raptor_WS6's Avatar
did you ever run it w/o meth?
Old 12-04-2013, 06:33 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Ahh, so it was a stock cam in it before. So I wouldn't expect to gain that much considering I'm running a 227/235 113lsa already.
FYI for those that asked about D1SC power potential, I made 742/688 a couple weeks ago with a pig rich (aka 10.2-10.4) tune with only 16 degrees of timing. No doubt it'll make close to 800rwhp once I clean up the tune.
Old 12-04-2013, 07:40 PM
a98ws6's Avatar
Any vids of the car is fine with me Martin.
Old 12-04-2013, 08:39 PM
I8UR4RD's Avatar
awesome! one of Martins Magic Bumpsticks is going in my blower car as well.
Quick Reply: 104rwhp/59rwtq gain Tick Performance custom blower camshaft
