Boost leak around injectors!
I have a Victor jr carb intake that I drilled for injectors, I had 60lb in it, and upgraded to 80lb. Now its leaking around 2 of the injectors when I ran a boost leak test. Do they sell over sized O rings? The 60s didn't leak, but 2 of these do. Should I just add glue?
When u guys need orings if whatever sort dont forget your local deere dealership.their parts dept can get any i.d./o.d./thickness/material you need ,most times overnite or onhand.. had hell with a bov oring awhile back and our parts dept has awesome access to nice orings made of whatever u want.getting a oversized injector oring wld be easy from them with a old one in hand.just a thot
Yes they are new, I thank you guys for the info. I would ask for part numbers, but I will just take one with me to John Deer, or call FIC!
A Oring seal is measured by both its diameter and thickness. Some are metric, some are english
Go to a Parker/Gates hydraulics shop, they have a lot of different O-rings sizes.
You may need to use a slightly thicker one. Use a little oil to install them to avoid damaging the seal
Thanks a lot. I called FIC they said the 80s came with the 14mm O rings,which is the thickest they had, so I will check on the parker&gates, and any other place I can find thicker ones!
call to verify
http://store.katechengines.com/fuel-...ring-p311.aspx
I can vouch for the ones from katech. I'm using them on my ls6 intake with the Siemens deka 80lb injectors before the would leak bad when I did boost leak test now no issues at all.
I went to John Deer, Kubota, and Part Stores! Finally I just told the girl to give me injector O rings for a 2007 GMC Serria with a 6.0. Looked at the lower&upper O rings, and the upper ones seem to be thicker so I installed them. Didn't do a boost leak check yet got to go to work!
