Name this alternator bracket
What alternator bracket is this, with the tensioner?
I will only be running a alternator off the crank. Factory LQ4 alt. it's perfect for what I need!
Electric radiator mounted water pump, manual steering and no AC or heat.
Thank you! That one looks to mount on the factory water pump! I wont be running the factory pump. I'll look into some that might actually mount to the head!
I am making a billet alternator bracket that mounts to the head basically. I am running 05+ corvette balancer and water pump on an lq4 with truck alternator only. It is going to mount to the driver side and incorporate a idler to improve belt wrap unlike the dirty dingo one.
So you are not running a dummy pulley on water pump?
No, my water pump is mounted to the radiator.
Basically will look like this!
The only thing on the block will be the hoses running to the AN fitting water pump adapter brackets.
