2000 s10/lq4
2000 s10/lq4
Hey for anyone interested in these swaps I figured I would share my current build. The truck is a 2000 S10 5spd/4cyl and very basic, the engine is an LQ4 from a 2001 Denali with a 4L65E. I didn't have any pictures of the trans rebuild and swapping it to a 2wd configuration. Everything was pretty clean for 120,000 miles on the teardown other than pitting on the cam and the cam bearings were pretty warn. I had the heads milled .030" for compression. This is my third swap so I was able to save some money by making my own harness and using hptuners to write the pcm. Ill make a list format of what Ive put in so far.
Felpro complete gasket and head bolt set
New cam, rod, and crank bearings
New sealed power Piston rings and lifters
Trick flow 220/224 cam
PAC valve springs
TSP hardened pushrods
CWP headers/mounts
H3 oil pan
Lokar trans dipstick (the last two swaps annoyed the hell out of me trying to get it to fit right and be able to easily bolt and unbolt it)
A/C fittings from Coldhose to make my own hoses and keep low mount a/c
Flowmaster 3" cat and 10 series muffler
Dirty Dingo Power steering pulley
2.2 Flexfuel pump
In the pictures I have some harness tidying up to do when I get my new loom, so ignore the visible wires.
PAC valve springs
CWP headers/mounts
H3 oil pan
2.2 Flexfuel pump
Very interesting battery placement. I'm trying to hate it but I can't. Low...passenger side...makes total sense. Maybe easier access to terminals to facilitate easier jumping..... but nice job!!
i have a 99 s10 2wd 5spd that im piecing all the parts together for my first ls swap. was there any frame or body mods that needed to be done to make it fit that couldnt have been avoided? i saw you did some welding in your pics just curious what that was for. any help is very appreciated thanks
As T72 said, the pan dictates much of your cutting. I went with the h3 pan so all I had to cut was the spot for the a/c compressor. That can also be avoided if you get a high mount(budget and tool dependant). I've always just modified the crossmember so this time I wanted to check out the Gforce.
