How much power have you seen old style rods handle?
Old 01-06-2014, 12:37 PM
Clean94Z's Avatar
Default How much power have you seen old style rods handle?
Whats the max you have seen old style rods handle? what HP do they typically fail?
Old 01-06-2014, 12:45 PM
Camaro9969's Avatar
This has been brought up a lot I bent the rods running a few 9.2@147s 3670lb car. Equals about 950hp 100 octane, this was an 01 lq4
Old 01-06-2014, 12:52 PM
mrstepheneades's Avatar
I'm in the 800rwhp+ range on 2000 ls1 factory bolts and all. Still OK but no serious track stuff either. Nearly all street. Car weighs 3400 without myself. Good solid load with no tire spin like in Doug's situation ^^ they wont last long I'm sure.
Old 01-06-2014, 12:53 PM
JustAFooL's Avatar
Interested in this too, just bought an l33 and as soon as I can get out of the driveway, I'm going to go to the bank so I can order an on3.
Old 01-06-2014, 01:02 PM
Clean94Z's Avatar
L33 come with the new style rods.. they can take more!
Old 01-06-2014, 01:18 PM
JustAFooL's Avatar
The pistons were trashed. I bought a used set of rods and pistons out of a genIII
Old 01-06-2014, 01:21 PM
Moderator
denmah's Avatar
high 9s at 140 in a 3300lb fox for about 1.5 years of racing, eventually bent a rod or two slightly.
race/pump mix, and methanol. 22lbs of boost and 15deg of timing.
Old 01-06-2014, 01:57 PM
Forcefed86's Avatar
LS1Tech 10 Year
Went 8's with my gen3 rods. 8.6:1 motor on E85 (5.3). 25lbs S475. Lost a timing chain and it took the motor out. I think I could have gone faster. (2850lb rx7.)
Here are my old gen3's next to the new gen4's I'll be running this year.
Old 01-06-2014, 02:00 PM
Camaro9969's Avatar
Weight is a big factor on these jy motors if you can build a light car you can run these stock motors "reliable"for a while with big power
Old 01-06-2014, 02:18 PM
slowlsx's Avatar
They have been up to 1200fhp
Old 01-06-2014, 02:24 PM
Clean94Z's Avatar
Gotcha
damn!! big difference
true true!! I saw that foose04 truck was running a gen 3 4.8 making some pretty sick power for quiet a few years.
Damn on stock gen 3 rods?
Old 01-06-2014, 03:02 PM
That is a huge size difference.
Old 01-06-2014, 03:45 PM
Camaro9969's Avatar
5.3parts's Avatar
Skinnies said he has done up too 900whp with gen 3 rods.. Said the tune has to be perfect
Quick Reply: How much power have you seen old style rods handle?
