Z06 Rocker Arm Upgrade
Has anyone upgraded the rocker arms on an LS6 motor (2004 Z06)? If so what length pushrods did you use and how many HPs did you gain?
I purchased a set of CompCam Ultra Gold Rockers..
Ok, well in that case aftermarket rocker arms should be the least of your worries. Even if the motor is modified the stock rocker will be more than enough to suffice. The only time you should be worried about running an aftermarket rocker is if you're also running an aftermarket set of heads that do not accept the stock ones. Hope this helps.
Consider returning the Comp Cams Ultra Gold's and doing the Comp Cams Trunion upgrade to the stock rockers instead. A lot cheaper and all that's needed with no chance of losing the needle bearings through the motor.
http://www.summitracing.com/parts/cca-13702-kit
